Scott06
- Joined
- Apr 20, 2014
- 7,366
Id defer to AD but would be thinking confirm injectors are openingConfirmed spark today with a spark tester.
does it cough if starting fluid is shot in there ?
Assuming this was a blue or white spark (3/8 gap) and it repeated this spark several times as engine was crankingConfirmed spark today with a spark tester.
I just purchased a basic code reader, its coming tomorrow. I will circle back with any codes it throws.Assuming this was a blue or white spark (3/8 gap) and it repeated this spark several times as engine was cranking
What we know;
Have spark
Fuel pressure is low but available at 30 psi
Remove flame arrestor, dribble a very small amount of gas down the throttle body. Crank motor and answer does it start or try to?
If it does try, get a Noid light and put on injectors when motor is cranking. Does the Noid light flash as motor is cranking?
Disconnect it to test bad tach can kill the ignitionOne thing that I did notice last time I was down at the boat is that while cranking, the Tach goes crazy. Not sure if that is relevant
