Tylermckee123
Thread starter- Joined
- Jul 26, 2025
- 3
So the boat is a 94 striper 210 that at some point had the engine swapped out, it's a carb motor that was converted to pertronix ignitiin/distributor.
I'Flamethrower coil, pertronix distributor. I've replaced the coil, replaced the ignitor II inside the distributor, new cap and rotor, and I've got no spark.
I have 12v at the coil positivewith key on, multimeter reads between 3-12 when checking coil negative to ground (test light pulses when hooked up this way)
I get a strong spark from the coil lead when held close to ground.
Still no spark to plug wires. I've checked holding a plug on a good ground, and using an inline spark plug test light.
I've verified my cap is making contact with the spring contact on the rotor, have continuity from top contact to bottom contact on the cap, continuity from top contact of rotor to side. Other than maybe the distributor is bad and grounding out what else should I check?
Side note boat was running fine, replaced starter and exhaust manifolds and boat started for 10 seconds then died and I've had no spark since. Only thing I can think of besides distributor is maybe while doing the manifolds I broke/shorted a wire somewhere but with the tests I've done I can't pinpoint what that would be. Previous owner/owners need to have their wiring priveliges revoked as most of what was done wiring related was crappy work. Stuff like 6' of extra wire coiled up, ring terminals with nuts and bolts covered in liquid electrical tape instead of proper adhesive heat shrink butt connectors, etc. I've fixed the bulk of that work already.
