Yeah not buying a Carter. I went through 2 of themauto parts Standard , oil pressire/fuel pressure switch
PS-64 or Carter A68301
Mines wired to a relay. I think it just isn't great around salt. Or I'm unlucky.the reason most fail is because the electric fuel pump starts drawing more current. this burns out the contacts in these and also the mercruiser ones. the trick is to run the fuel pump thru a cube relay and just use the pressure switch as a contact point for the low current internal cube relay
Where is the sticky?Napa has 3 pin oil switches in stock
I have links to the catalog in the electrical stickies
Yup this is how it’s hooked up. I have power from 50 amp breaker to relay for 12v they wire from ignition switch to oil pressure switch. Then pin from switch to yellow wire to relay. Just not getting 12 volts from the yellow wireUse the switch to power a relay
Use the relay to power a fuel pump
Pin 30 to power
Pin 85 or 86 to the oil pressure switch NO contact
Ground to oil pressure switch C contact
Pin 86 or 85 to the ignition switch
Pin 87 to the fuel pump
Never had good luck with Standard parts. When I was tech we use to have a lot of returns of faulty sensors.auto parts Standard , oil pressire/fuel pressure switch
Yeah I use a relay alreadyLots of pressure switches here
One has slide on terminals, one has screw on. And you should use a cube relay.
Amazon.com: Acogedor 309-0641-03 Oil Pressure Switch Low Alarm 1/8 NPT for : Industrial & Scientific
Amazon.com: Acogedor 309-0641-03 Oil Pressure Switch Low Alarm 1/8 NPT for : Industrial & Scientificwww.amazon.com
But you can use a 2 wire NO switch, and run a wire from starter to the fuel pump and get pump running as engine cranks without using a relay. Run it off the starter solenoid 'R' terminal, it only gets power when engine cranks over by starter. Years ago, 'R' was used to give full voltage to the ignition coil when cranking, bypassing the coil resistor.
starter solenoid 'R' terminal, - Bing
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.www.bing.com
I have the adapter on there already. Just want to find one that will last and not die after 30 days like the Carter one.if you find one in the brand you want but its 1/4" you could use an adapter like this
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
these guys may have one -I have the adapter on there already. Just want to find one that will last and not die after 30 days like the Carter one.
www.partdeal.com
You can go to a typical reliable Mercruiser oil pressure switch with 2 terminals, 1/8" NPT.I have the adapter on there already. Just want to find one that will last and not die after 30 days like the Carter one.
powerboatsupply.com
