Alpha 1 Gen 1 Upper/Remote Shift Canle Help
TruDaddy
I am having issues on my alpha 1 gen 1shifting in/out of reverse smoothly.
I checked the lower cable for slop. It was 3/8" and in spec. I set it center to center 6".
I moved to the upper cable or remote cable. The travel from WOT forward to WOT reverse is 3 1/4" I believe this makes it out of spec by 1/8"
What is my next move? Is it an adjustment or do I replace that cable? How do I make sure I purchase the correct cable?
TruDaddy
Update: I have a gen 1 mercury control cable. I removed and measured (163"). I picked up a new cable at the local boat store. I measured the complete travel of the cable not mounted to anything. It is greater than my old cable. Am I missing something? Will the cable travel be less when mounted to the throttle control? I will mount it to see and report back.
Phillip_333
Sounds like you’re on the right track. Lower shift cable connects on the fwd side of the lever in a slot with adjustability. After doing full shift adjustment procedure (looks like you already have), slide that cable up in the slot until good shifting is achieved. Movement in the slot should not affect your fwd gear engagement.
TruDaddy
Update: Mounting the control cable to the throttle does limit some of its travel. The travel from WOT Forward to WOT Reverse is 3 1/16". This is within spec. Time to mount to engine and continue calibration.
As you found the amount the cable can be moved unconnected has no direct bearing on how much it will move when connected. The throttle control is the limiting factor
TruDaddy
Update: Shifting in and out of reverse is much improved on muffs but must splash to find out. It does appear that shifting out of neutral forward or reverse is not immediate. What is normal for travel on the throttle handle forward or reverse before the dogs engage? Can I tighten?
TruDaddy
You don't want to be opening the throttle plate before the shifting has engaged completely
I understand why that is important. Doesn't following the specs from the manual ensure that doesn't happen? If not, what are the finer tweaks/adjustments that should be made?
How far forward/reverse on the throttle controller should it travel when it goes into gear and then applies actual throttle or "thrust"? I ask this way because tge throttle controller is the only feedback I receieve when driving. I cant look at linkages.
nola mike
It should
No exact point on the controller. You can tell easily enough though, as long as the engine doesn't rev before the drive clunks
kenny nunez
The shift control should move the cable 1.5” for forward or reverse. If you have a genuine Mercruiser control that is what you will have.
If you have a generic marine control with extra holes on the levers sometimes you will have to experiment to get the required cable movement.
Also if your control is generic and is rigged with universal cables that can add adjustment problems.
Genuine Mercruiser style cables have very fine threads for adjustment.
TruDaddy
I do have official Mercury Gen 1 Cables and a Quicksilver Commander controller. I splashed the boat yesterday and it does shift in and out of gear a lot easier but I do feel like it is a little Spongey or not as immediate of a shift response when docking. Is this normal? Will raising the adjustable stud slightly help make this a bit less spongey?
Side note: Has something changed? I cannot upload or attach pics without getting an error.
TruDaddy
I am having an issue. When shifting into reverse the shift interrupt switch does not move. It moves as expected in forward. The cables have their primary adjustments to specs. Not sure what to do.
Ayuh,..... The shift switch should Never move, shifting Into gear,.....
Only when coming Out of gear, in the water,....
