clearbluewater
- Joined
- Aug 19, 2019
- 46
Hello All,
2007 VP 3.0L, Holley 4150 double barrel
I will be starting my boat after 4 years in indoor storage. These are the items I plan to cover before start up
1. Remove all old fuel
2. Add brand new fuel with stabil
3. Change engine oil and filter
4. Swap fuel filter (primary)
5. Inspect secondary fuel filter. Not sure where it is yet.
6. Change impeller
7. Change gear oil
8. Carburetor rebuild. This is because I saw a small fuel leak last time I used it and was advised by a member here to swap the carbureter gaskets. Also had to raise the throttle to start the motor till it got warmed up. Didnt start just on idle with turnkey.
This is the kit I got
Let me know if I'm missing anything or should check prior to start up. Thanks in advance.
6. Change impeller
7. Change gear oil
Autu Parts 21533394 Carburetor Repair Carb Rebuild Kit Fits for Volvo Penta 3.0L 4 Cylinder : Amazon.ca: Automotive
a.co
