wellcraftpower
Thread starter- Joined
- Jun 29, 2022
- 44
5.7 vortec heads , my torque spec sheet gives 2 different ways to torque with angle torquing being prefered. I don't have that wrench, is it necessary.
On the wifes mini I bought HF angle torque wrench broke on the second bolt... so I just marked the bolt heads with a sharpe for the angles. I dont think the angle is that precise5.7 vortec heads , my torque spec sheet gives 2 different ways to torque with angle torquing being prefered. I don't have that wrench, is it necessary.
HF now has several torque-angle digital wrenches. Which one broke?On the wifes mini I bought HF angle torque wrench broke on the second bolt... so I just marked the bolt heads with a sharpe for the angles. I dont think the angle is that precise
This POS, yeah it’s sold under abiut 15 different brands https://www.harborfreight.com/38-in-drive-5-to-100-ft-lb-digital-angle-torque-wrench-64915.htmlHF now has several torque-angle digital wrenches. Which one broke?
(I'm pretty sure they're all rebranded tools from other mfrs)
Yep. Not high on my list of desirable torque wrenches. Same tool as Eastwood, Westward, AC Delco, + many others. All made in Taiwan by Eclatorq with very slight cosmetic differences.This POS, yeah it’s sold under abiut 15 different brands https://www.harborfreight.com/38-in-drive-5-to-100-ft-lb-digital-angle-torque-wrench-64915.html
the rachet head broke set at 85 ft lbs. I bought a used snap on, No sense screwing around with angles on a cheap wrench. Because this was middle of doing a timing chain on the wife's mini I punted and just marked the bolt head for the angles, which also worked just fine as long as you can get at the bolt head.Yep. Not high on my list of desirable torque wrenches. Same tool as Eastwood, Westward, AC Delco, + many others. All made in Taiwan by Eclatorq with very slight cosmetic differences.
Still shouldn't have broken if used within it's capacity. The ones I've used & calibrated have always gone to 100% without fail.
Digitals have an annoying habit of going to sleep while you delay getting going...then SNAP!
the bolt is what stretches. I think bolts designed this way hold their torque better.What is stretching ?
