Will boat for this style trailer?
HoosierHacker89
Extend those bunks rearward to support that transom, then add a keel roller on that cross member so the bow doesn't hit. Do yourself a big favor and add some side bunks to keep boat centered. You could just raise the front mount of the bunks to get the bow a little higher. My boat sits at an angle to the trailer tongue ( bow is higher) makes shallow ramp launch and loading much easier. I would keep the rear bunk kount as low as possible to help with shallow ramps.
Trailer has a couple of those side bunks. I took off just to make sure I can get back on the trailer easy. To fit width.
cyclops222
The middle and back of the trailer & boat look very good together. Leave that alone.
Bow pictures are not very clear. Looks like a lot of needless stuff on it. What is that massive black painted part ? Can you post a side view of the winch area parts ?
FLATHEAD
I have a couple 2x4x8 I’ve been saving for such an occurrence. I’ve seen some guys say pressure treaded good, good some say not good. What say you?
That’s a tool box in the background
airshot
If that were my trailer, it would have a keel roller on each crossmember. Ask any mfgr....the strongest part of any boat is the keel ! Just be sure the bunks support the majority of the load. Folks that cause damage to their hulls/keels don't have enough rollers. My 1983 Aluminum boat sat on a roller trailer its entire life, it had twice as many rollers as most trailers, to this day no dents or damage...
airshot
I don’t know they can be raised without some external parts. I’m sure I can buy something though. I just learned last night there is a difference between Jon and v hull trailers. (I’m sure everyone else knows this already) The cross members on the v hull trailer will be recessed to prevent just this.
Not all are made that way, rather than recessing the cross members they add keel rollers. Many trailers are designed for heavy fiberglass boats and other are designed for lighter aluminum boats. Some trailers are just bunks only and other are all roller trailers, and others are a combination. Most can be setup for any boat if the weight rating is ok.
airshot
No pressure treated wood !! Regular wood 2x4's work fine. Cover them with carpet but leave the bottom open....this is so water is not trapped and the wood will dry over time. Replaced my last bunk trailer with plain old wood and they lasted 8 years. Once you have everything setup, replacing a bunk is not hard, so long life is not a big issue. Just keep the bottom side of it he bunk open to help dry. Looking at your pics....you said your ramp is shallow, hard to load/unload....so lower the rear bunk support if you can, the lower the boat, the less water needed. My ramps are shallow, my boat runs uphill toward the winch to make launch/load much easier. Keeps the stern closer to the water so much easier to L&L...
airshot
Right now the Winch is too high on the Winch Stand, the Strap should be pulling Horizontal-Level to the Bow Eye. However once you Rise the Bunks, it may be fine.
I agree, however, I would try raising the front to get the bow eye higher and lower the rear of the bunks to get a better launch in shallow water. No law that says the keel must be parallel to the tongue, if you look closely, you will see many boats with the bow higher on the trailer, common practice for launching on shallow ramps.
HoosierHacker89
I put a keel roller under bow last night: it had helped raise front of boat up a little. I will raise bunks as well and we should be good to go!
jimmbo
Which took weight off of most of the Bunks, and concentrated it on the Bow Roller, and the rear of the Bunks
HoosierHacker89
What do we think about this: from stern to now
Leaving bunks as is at stern mount at transom, mounting 1x4 under middle set is hardware, mounting 2x4 under furthest to bow hardware to create angle.
jimmbo
As long as the Bunks are not being bent, which I feel they will be, as the Bunk at the Transom is bolted to the Bracket, and will not be angled upward.
I would just raise the Entire Bunk Equally. Launch Ramps are sloped. As long as about 60-70% of hull's weight is displaced, the boat will back off the trailer quite easily
HoosierHacker89
I’ve been looking online and there really ain’t a bolster small enough to do what I’m hoping for. Doubling up the 1x4 or 2x4 on the bunks seems to be the easiest plan.
HoosierHacker89
I think I got it! I moved the bunks just inside the keel/stringers things and seems to launch and I launch super easy. Raises it just enough no issues in very shallow water. That roller upfront gets bow up just a little.
HoosierHacker89
I went to Marina tonight and boats i looked had the bunks just outside the strakes instead of just inside like I’ve done on this trailer. Are the bunks being just inside the strakes an issue or am I ok? I’ll buy a 4x4 or do 2x4 on side to do my bunks on to raise bunks on trailer up if they need to be on outside.
