Picked up a 1990 Force 50HP yesterday.
metalchewy
Went and pulled a 1990 Force Outboard 50 model 507X90D, from a 1990 Bayliner boat yesterday for a pretty decent price. Got the steering, throttle, all cables, plus the electrical all the way to the battery with the deal. It hasn't run for three years. But was running when the guy we got it from purchased the project.
Checked compression and spark before we started. Both cylinders just over 140lbs compression and sparking on both plug wires.
We plan on putting it on the fishing boat we are building from the hupp up.
Ordered carb gaskets and a new needle. I'm sure the bowl is varnished and want it fresh/clean before we try to fire it up. Will install a telltale while I'm at it.
A new impeller is also on the way as well as new spark plugs. The old plugs look new and we can keep them in the boat box when we finally launch, as spares on the lake for 'just in case'. We will hopefully have it ready to launch in November.
When the parts arrive will be getting started to ensure the engine and drive are sound. Hopefully things will go smoothly.
Can't think of anything I'm missing on getting it ready for install in a few weeks. Fingers crossed...
tg3690
Don't they all say that? Sounds like you got the basics covered (comp-spark-carb-impeller). Wouldn't hurt to take the carb off and clean it real good, check the float level, etc, since it's been setting up for a few years. Good luck.
metalchewy
The boat we took it off of hadn't been licensed in 15 years. The guy bought it as a project, and didnt have the skills to execute it. My friend went through the floor trying to get up front to the battery.
My guess the person he got it from tinkered with the motor long enough to make it run so he could sell it. IMO, Without redoing everything from the hull up, the boat was worthless, except for the engine.
We plan to put a lot of hours on the motor fishing, so gonna make sure all is well while it's on the stand before trying to mount it.
tg3690
You are right, especially if it was an old fiberglass boat. At least you won't have a worthless hull to get rid of. Not sure what the completion rate is for project boats, but from what I have heard it is not very high. They start out with great intentions, but soon realize it was a lot more than they bargained for. A free boat can end up being a very expensive boat.
jerryjerry05
tg3690, shame on you. Don't rain on his parade, he's just getting started. :)
Metalchewy: you bought a good motor, they will last a long time, just use a good oil and keep up the maintenance.
That motor needs a special set of muffs for running off the hose.
That motor can run on 1 cyl. and run fairly good.
No muffs? run it in a DEEEEP bucket, at least 4-6 inches over the cavitation plate.
The pump isn't self priming and needs to be under water to pickup.
Good luck with your project!!!!
Read the first 5 post in this forum. Lots of tips and help for Force/ Chrysler motors.
metalchewy
I saw those muffs in another thread the other day when I signed up for the forum and was reading through a lot of the threads. Wasn't sure where to get them. Searches didn't seem to find them.
I don't have muffs, but I have do a 55gal plastic barrel that should do. Even rolled it out of the yard to the side yard the day we picked up the old aluminum Texas Maid. Build thread here -> https://forums.iboats.com/threads/building-a-fishing-boat.780119/
tg3690
I was referring to the boat he took the motor off of......a project the previous owner never finished. I see that he has an aluminum boat he will be restoring to put the Force on. He won't have to worry about endless hours of grinding rotten wood, old fiberglass, etc. Should be a lot easier to fix it up the way he wants it. Didn't mean to rain on anybody's parade......(y)
metalchewy
I caught what you meant, and am thankful I don't have to figure out how to dispose of the the donor boat we got the engine from.
tg3690
I think the dumps around here will take a hull, not sure how much that would cost.......then there is the old trailer you would have to deal with, too, if it had one.
metalchewy
It had a decent trailer. But have no use for it. The trailer we got with the boat needs alittle TLC and paimt work but has a permanent license tag on it. When we title/license the boat, will transfer that to a new title.
jerryjerry05
I love all the sellers saying.
" It ran when I had it. " But it stopped when you bought it
Back before I started working on anything(cars, boats etc.) I had a 15ft. trihull with a late 70's 85hp Mercury. I decided to go up to a bigger boat. Bought a 31ft.cabin cruiser. The 85Mercury ran good and then started to get hard to start.
Sold it to a guy who insisted to start it. I turned the key and it fired. The guy really got it REALLLLY cheap. I made sure the bill of sale said AS IS!!!
Turns out the middle cylinder had blown and had low comp.
He let it set for 3 years and in the mean time I started working on boats. Went to work at a local repair shop and the boat was setting there waiting for the motor to be rebuilt. Make double sure of anything you buy and the words AS IS is very important.
BUYER BEWARE!!!!
metalchewy
BUYER BEWARE!!!!
Sometimes they still run, but buyer still beware...
Back in 86 my my first car had sat for 7 years next to a barn down the street. Dad and I had been looking for a car for a couple months for me to start in. We had looked for few months, and he asked the owner about it. Owner said it ran fine when parked, was just replaced when he bought his wife a new car.
73 coronet 4-door 318 car. Dark metallic green under the leaves and sediment, with what I thought was a tan vinyl top.2 flat tires. Dad had me pull 2 tires off of an old satellite with a blown Trans sitting next to our barn. Put those in the truck, 5 gallons of gas and a battery.
Put the tires on, battery, and gas in it, primed the carb and it fired right up. Dad paid the guy $75. I drove the truck back and he drove it up the street to the house and parked it on the lawn, had me wash it. Then said let's take it for a test drive. You drive.
Got it up to 35 miles an hour and he said. Stomp on the brakes hard. One front tire locked up and the car almost did a 180. He said, drive it back in the house and park it in the garage. As we pulled in, he said, it needs rotors, calipers and brakes up front. Told me which box in the top of the barn had them, and said I'll be in the house if you have questions. Look in the motors manual for instructions.
Three hours later I went in and told him it was done.
Paint was shiny, Vinyl top was white. Looked like a grandma's car. With some timing adjustments, it was the strongest stock 318, I've ever run.
A couple years later, I ended up giving it to one of my brothers after I picked up a 78 nova. Wish I had either of those cars now...
jerryjerry05
(Three hours later I went in and told him it was done.
A couple years later, I ended up giving it to one of my brothers after I picked up a 78 nova. Wish I had either of those cars now...)
AH!! the good old days. Over the years I had 4-5 different Novas and a couple Pontiac Lemans. I'd take any one of these over the crap we run around in now. I have a 1999 Chevy Astro Van. It has 7-9 different sensors for different operations. ANY one of these sensors can cause the motor to not run. :(
Like Reply
cyclops222
So glad I got rid of brand new Chevy 1967 Chevy convert. SS 396. It ate hydraulic lifters. Wife drove it mostly.
That is when I bought a first Honda shoebox sedan 1975 ? First year they sold them in USA. BEST CAR ...EVER MADE !!! No PM BS It ran forever. Replaced floor sheet meat 3 times due to USA salt on roads
metalchewy
Had a friend back in the early 90s that had a 75 Datsun B210. He loved that car. It always ran and seemed to be immune from the winter salt.
guy48065
Best friend has a 67 Chevelle 396SS. Stroked to 454. Worth about $70k now. He hasn't mentioned anything about lifter issues. 😁
Buster53
You can buy muffs anywhere that sells any boating supplies, even Walmart and Amazon. Get the muffs….way easier than manhandling a 55 gal drum. Just google outboard motor muffs.
metalchewy
To run with muffs, it sounded like I needed those special muffs that @jerryjerry05 posted above for and old force outboard. The barrel will work until I find those ones.
If a regular set works, I can pick them up at sportsman's or a local boat shop, before the parts arrive, and not deal with the barrel.
