saltchuckmatt
- Joined
- Jul 19, 2019
- 3,350
I found your problem. Evinrude doesn't use the I and the S on there's. The I stands for ignition and the S for start.That was step three haha. My push choke works so the fuse is working. Without the fuse, the choke doesn’t work.
I have another, better quality solenoid arriving tomorrow.
The S in this case means Start, but by completing the ground.
You have it wired in reverse. The hot signal wire goes to the top mini nut or what should be the I...and the ground goes to the S or the mini nut that's closer to the battery lead.
Switch them then enjoy life!
