Volvo Penta 270 5L V8 power steering issue
bongoray
Hello all,
First time boat owner here. I purchased a used 2014 Monterey 234 SS with a Volvo Penta 270 V8 engine. Everything has been working flawlessly until a couple of weeks ago. I docked the boat like normal and the next time out, I had barely any power steering. It seems to have some at slow speeds, but it's basically non existent. The fluid reservoir is full, there are no leaks. The serpentine belt is in great shape at proper tension. There are no odd engine noises. The power steering pump pully spins smoothly with no noticeable issues. I removed the pins holding the actuator and outdrive steering linkage and the outdrive moves side to side by hand smoothly. The steering cable moves freely with the wheel input. It's a gear driven single cable. I removed the cable from the helm and I can push/pull it by hand relatively freely, but I don't have any reference. The helm helm gearbox rotates smoothly with no odd noise.
Any thoughts on the next step for trouble shooting? Maybe install a pressure gauge on the power steering pump to see if it's making pressure? The actuator appears to be moving as it should. The shuttle valve (I think it's called) moves side to side with steering input. There's no obvious signs of an issue.
Thanks,
Ray
Start with a fluid change. Pull the PRV valve, remove the clip, pull apart the stack, clean the parts and reassemble.
Will cost you 2 hours and a few quarts of oil
bongoray
Thank you so much for the suggestion. I’ll try that. Stupid question. Where is it located? Is it part of the power steering pump? Or somewhere downstream?
Back side of the pump. It's the hex shaped thing the pressure hose is screwed in
Google Saginaw can of ham pump prv
Donald0039
There is not a lot of wear that happens in a PS system. While a change of PS fluid can never hurt, in this case I doubt it's your problem.
The PS pulley is on tight?
bongoray
Yup. Pulley is fine. No slop. No axial or radial movement.
bongoray
So I took out the PRV and it looked super clean. I didn't bother taking it apart to clean it. I did get the genius idea to see if I could get the spring to move by tapping it lightly with a hammer and bent the pin slightly. Ugh, then I must've galled the OD of the valve body, because it would not re-install smoothly. Now it's stuck and I've had to order a new power steering pump. So at least I'll know if that's the problem. Should be here tomorrow.
or $65 on a new pump insert (was $35 just a year ago)
kd4pbs
You should be able to get a replacement at your local Peppy O'Reilly Auto Doodle Zone Boys.
I appreciate all of the suggestions, but I cannot find these parts online anywhere. I'll have to bring it to my local marina and try with them.
seriously, look at a 1996 Chev truck power steering cartridge. GM has used the Saginaw power steering pump for well over 70 years.
google Saginaw Power steering pump or Saginaw power steering pressure reducing valve.
muc
"Retired" Association of Marine Technicians...
I think boats use a different pressure relief rating?
Boats use the same 1100 psi valve as GM
bongoray
Default
I've replaced the pump and power steering is back. It's not perfect but it's better than it was. I think my next step is to replace the steering cable. I remember the steering being smooth and effort free all the way through the range of motion and at all speeds. It doesn't seem that way any longer. I'll keep all posted. Maybe this will help someone else.
