Spark Plug suggestions!
68glasspar
I have 1969 85hp Evinrude, Model85993E. The original manual says champion L-19V.
I'm looking for suggestions for something other then Champion. Something that others have had good luck with. I'm in Wi. with elevation of about 1000ft Above SL. This engine is just going to be used for running around, probably no water skiers!
matt167
Autolite 2852 is very close. The problem is that Champion had a handle
On the marine plugs for a long time, so
The OEM marine rated plugs sometimes do not have a direct match if you venture outside of the spec plug and just try to cross it
jimmbo
The AC plug equivalent was V4OFF. I preferred them to the Chumpions
jimmbo
That was they were speced for. Back then there wasn't a Conventional Alternate. Use of a Conventional Plug actually alters the Ignition Timing Slightly by placing the point of ignition closer to the Piston.
I like the Surface Gap Plugs and had a Set last over 14 yr at about 600hr on them, and never had a Misfire due to the Plug.
68glasspar
Thanks! Thats the answer i was looking for!
Nordin
NGK BUH is a replacer for Champion L-19V.
Surface gap style plug.
airshot
Do you have any experience with using those plugs? good or bad?
I have always had better success with NGK over Chumpions...I was also forced to switch to champions due to NGK no longer producing their plug. So far, so good, no complaints yet....
Nordin
As I am in Sweden Europe, it is easier to find NGK than Champion.
I have NGK BUX surface gap style in my Mercury 800 1972.
I have also NGK surface gap style plugs and Champion UL18V (surface gap style too) in a couple of Chrysler 70-75Hp.
Both brands have been good in my OBs.
68glasspar
My ebay purchase of the V40FF spark plugs fell through! Back to searching
flyingscott
Isn't the QL77jc4 the superceded plug for a 1969 85 hp? That plug will work well in WI.
