My 1978 Holiday 18 Resto Adventure begins!
Poisonous392
Hi all,
Just documenting my adventure here with my 1978 Holiday 18 that i just picked up a week ago. Look forward to hearing from u all and learning from many!
Building this for myself since I can no longer fish off the FishPro after a work injury and to take the granddaughters fishing.
Let the journey begin!
IslandExplorer
Sweet Holiday, looks great already! Curious what motor you have, good old Merc 165? Looks like you have a great starting point for your project.
Poisonous392
Pulled all the flooring and replaced today. May have lasted another season so I tore it out. Foam under floor was excellent. Before i rivet it down, im gonna add aluminum cross members to stiffen it up. Increased it to 5/8 thick. I'll post pics tomorrow. Haven't weighed it yet. Heres the old floor
IslandExplorer
The switch from 1/2 (factory) to 5/8 makes a huge difference. Seems like it wouldn't but the 5/8 is a hell of a lot stiffer between the spans, feels way more solid. I chose the same for mine and am very glad I did. That's great that the foam made it!
Poisonous392
Well half the foam made it lol. The lower 1" pieces were filled with years of water. Gutted it for new foam and adding in cross bracing.
The 1/16 aluminum the used between each section is no bueno... and kind of a joke.
I'll post more pics when bracing is done
IslandExplorer
There ya go, nice to get that crappy old wet foam right out of there. The cross seam strips do seem extremely light on these decks, esp once separated from the plywood. They really only act like tape holding the seam together even, don't think they add squat for rigidity. The factory (2"?) width stuff doesn't leave a whole lot of space from the edges of the plywood for the rivets either. Looking forward to seeing the bracing!
Poisonous392
Bracings in. Lower foams in.
Thats all the bracing needed. Tested with new floor. Sturdy as a rock.
redneck joe
It is a thin epoxy that seals from the inside, i needed 1.5 cans for my 18 foot so I used the half to double up on the keel rivets where most of the issues were. It ain't cheap, but you are this far in.
redneck joe
AI Overview
+14
According to boater forums like iBoats and user reviews, Gluvit epoxy is widely considered an effective and durable product for sealing leaks in aluminum boats, especially around rivets and seams. Users report that it works well and can provide many years of leak-free performance when applied correctly.
Pros of using Gluvit
Effective leak repair: The thin epoxy is designed to seep into the tight spaces around leaky rivets and seams before curing to a hard, waterproof seal.
Flexibility: Unlike some rigid epoxies that can crack, Gluvit is designed to flex with the normal movements of an aluminum boat hull.
Abrasion resistance: Once cured, Gluvit creates an abrasion-resistant barrier, which is particularly beneficial for the bottom of the hull.
Corrosion prevention: It acts as a barrier coat to minimize corrosion, especially in saltwater environments.
Versatility: While popular for aluminum boats, it can also be used on fiberglass and wood to seal cracks and strengthen deteriorated areas.
Cons and considerations
Application is messy: Many users note that Gluvit is a messy product to work with and can run or drip while being applied, especially on curved surfaces. You may need to sand off any dried runs after it cures.
Requires thorough prep work: For proper adhesion, the application area must be thoroughly sanded and cleaned with a solvent like acetone to remove all contaminants, oil, and grease.
Not UV stable: Like many epoxies, Gluvit is not UV stable. To prevent degradation from sunlight, it must be overcoated with a compatible paint after it cures.
Limited work time: The product has a limited "work window," which requires you to mix it in smaller batches for larger jobs to avoid wasting material.
Variable user experience: While most feedback is positive, some users have reported issues with the product not curing properly, which could be due to old stock, improper mixing, or incorrect temperature.
Bottom line
Gluvit is widely considered a worthwhile investment for sealing leaky aluminum boat rivets and seams. Its ability to penetrate and flex makes it a reliable, long-term solution. However, achieving success depends on proper surface preparation and careful application. You must also account for the extra step of painting over it for UV protection.
Poisonous392
No, I read it didnt work that well for some people. Ive got a small leak at the keel. Nothing major and im going to drill out the solid rivets and seal it with 5250 i think it is and reinstall solid rivets again.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
I redid all my rivets and 5200 everyone. I still went back over it with Gluvit. Prep is key as in any job. Wire wheel, then degrease before putting on Gluvit.
SHSU
redneck joe
It is an additional layer of protection / insurance while you have the thing apart. For $150 you may not have future leaks.
'Some people' also do not follow instructions so it will fail for them.
Your call.
Poisonous392
Havent been on in a while. Had some time to work on boat today, test motor and winterize it. Going in garage to continue work through winter. Attaching a short run vid
  • IMG_1313.mov
Poisonous392
Can someone confirm for me what type of outdrive this is? MR or Alpha 1?
