I have a 1995 Alpha 1, Gen 2 on a 5.7L V8. There is no water in my outdrive oil when drained but there is some milky gear lube in the bottom of the reservoir and the level has been dropping. I need to add gear lube every 4 hours or so of running. I also maxed out my boat weight once this summer and ran full rpms. When I opened up the engine compartment, there was a good amount of gear oil that had escaped from somewhere in the system. I had a mechanic take the outdrive off and pressure test and it was fine. Any suggestions on where it would be leaking from?
