Planning for spring tune up
DeepCMark58A
I put the mastercraft to bed and in storage till spring. I am planning the spring tune up and rather than points thinking of going electronic instead some say it is a difference maker in performance and ease of maintenance. does it really make a difference?
Grub54891
Yes. No more cleaning points, setting dwell, and timing. You still have to check the cap and rotor to make sure it’s in good shape but that’s just regular maintenance.
I take the point plate out and put it in a waterproof container and stow it onboard for emergency. That way if the electronic system goes down I have a backup that will get me home if need be. Never had to do that but it gives me peace of mind when I’m out far on Lake Superior.
mr 88
Personally I would drop a electronic distributor in vs a Petronix set up , which also means a different coil . This will not fail you like a Petronix might ( I've had one let go ,coil ) or the points crapping out . Yes , I know you can adjust the points or put new ones in while at sea . Just the thing you want to do with a boat full of guest and 2-3 footers rolling you around while messing with the points .
