redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,457
My current battery is use for starting and as my trolling motor backup is a 2018 deep cycle, not sure how many CCA but never had an issue and usually kicks in about 15 seconds and it came from my Carver with a 5.7 mercruiser as the starting battery.
First question is I've read one should not use a deep cycle for starting it will damage things. In a quick search my 50hp needs 500 or so CCA and a 115 (max rated hp) would need 750ish. As long as i get enough CCA on a deep cycle can I not enjoy the benefits of both?
Second question is the current set up is nine inches tall, plus connections so about 11.5 inches tall. Is there a battery that fills the above but is a couple inches shorter for where I want to place it?I looked at a battery group chart and was immediately overwhelmed.
I guess third questions is... could i relocate battery? How long of a run from battery back to the original location where I could put a bus bar or whatever it's called.
