MikeSchinlaub
Ensign
- Joined
- Jan 14, 2025
- 974
Very good illustration of what I was trying to describe about how boats settle onto trailers. Thank you.Here is what may be happening . . . My 24 footer would do this all the time.
And slightly pulling upwardsIf you look closely, you can see the strap on mine is almost horizontal, I like this pivoting winch bumper design, never have had a problem with it as long as it's adjusted to the correct height.
Rewind the strap around the drum so it comes off the bottom. Worry about getting it against the stop next time you launch, unless you plan on doing a long drive in its current position.From an older photo, boat loaded all the way forward.
So what do I need to fix so it's not "all wrong"?
Probably from quick assembly from the factory. In every boat trailer I have owned ( probably 2 dozen or more) and having worked at a marina/ boat dealer, every trailer I have saw has the safety chain pulling down toward the tongue....this also.makes them much easier to attach with little play. Your boat, use as you wish, but think about the geometry and what the chain needs to do in case of an emergency.I agree but it seems like all safety chains/cables come attached to the winch post.
I see a lot of bass boats where the safety is just another length of strap stitched onto the winch strap.Rewind the strap around the drum so it comes off the bottom. Worry about getting it against the stop next time you launch, unless you plan on doing a long drive in its current position.
