Texasmark
- Joined
- Dec 20, 2005
- 15,055
Well why is it built like no other 2 stroke engine?I do not believe that the 4 cylinder 2+2 was meant for extended trolling.
How is it built like no other 2 strk? All they did was take the idle circuit out of the carb, Hardly groundbreaking. More than likely an attempt at lowering emissions and improving idle quality.Well why is it built like no other 2 stroke engine?
I will disagree with the trolling aspect. I know a lot of people who have trolled with those and have no issues.Agreed---There is nothing special about this motor.---Very little fuel goes into the lower 2 cylinders at less than 1800 RPM.-----Not a setup / motor I would trust for long term low RPM operation.
What are you talking about?Tuned intake or exhaust systems do have sharp up and down change points.
".........and improving idle quality." Ha! My '88 I6 tower of power was the smoothest idler I ever bought! It also liked to run at 6k RPM.How is it built like no other 2 strk? All they did was take the idle circuit out of the carb, Hardly groundbreaking. More than likely an attempt at lowering emissions and improving idle quality.
All I said was they did it to improve idle quality in that motor. What your I6 has to do with anything is beyond me. But it seems to have your undies in a bunch.".........and improving idle quality." Ha! My '88 I6 tower of power was the smoothest idler I ever bought! It also liked to run at 6k RPM.
No, comparing the Mercury 4 cylinder back in the 50's to the OMC 2 cylinder engine, more cylinders firing made for smoother operation.....I had both. So what part of that don't you understand. How can 2 cylinders idle more smoothly that a 4 cylinder engine, much less a 6 cylinder? Makes no sense! If fewer were better, why not just save a lot of assembly costs and just have one big cylinder? I had a couple of those....Mighty Mite 1.7 Hp and 1970's era Mercury 4 or 4.5 HP forget which when I had my smooth running 4 cyl. 85 HP Merc.....I fixed up a boat for the kids when they were old enough so when we went fishing they had their own rig. No way Jose!.......figure of speech.All I said was they did it to improve idle quality in that motor. What your I6 has to do with anything is beyond me. But it seems to have your undies in a bunch.
Good deal, glad for you and disregard the noise on this thread about anything else.I did the compression test today 130 psi even on the 4 cylinders, deal is closed!
The service manual for that engine states that anything below 120 expect problems......looks like you are good to go!I did the compression test today 130 psi even on the 4 cylinders, deal is closed!
No doubt they were/are reliable. My experience with a dozen give or take of the brand proved that point to me or I wouldn't have continued to buy the brand over several decades....converting from OMC back in the 1950's. No doubt they are/were popular especially if you wanted a Mercury in that vintage in that HP class,They made a lot of them, and a lot of them are still in Service, so they by virtue of time alone vs how many still exist means they are fairly reliable.. I got one for free once helping an old guy swap a different motor on his boat. He hated the surge in power. As I recall he put a Suzuki 90hp on his boat. I didn’t want the motor, but he insisted I take it, so I kept it around for a while and then sold it cheap to a guy and his son who were looking for a cheap motor.
Well I would imagine your 115 with all the jury rigging done to it doesnt idle all that great. When I hear people talk about the tower of power Smooth idle is not the first thing mentioned. More cylinders does not mean better idling , the best idling motors are the old OMC 2 cylinder outboards. 3 cylinders tend to idle better than 4 and so on. The 2+2 is an incredibly good idling motor when set up right. And if 4 cylinders idle better than 2 why did Mrrcury make it a 2+2? Considering what you did to your 2+2 I don't think I will take your opinion on good idling. But hey you be you.No, comparing the Mercury 4 cylinder back in the 50's to the OMC 2 cylinder engine, more cylinders firing made for smoother operation.....I had both. So what part of that don't you understand. How can 2 cylinders idle more smoothly that a 4 cylinder engine, much less a 6 cylinder? Makes no sense! If fewer were better, why not just save a lot of assembly costs and just have one big cylinder? I had a couple of those....Mighty Mite 1.7 Hp and 1970's era Mercury 4 or 4.5 HP forget which when I had my smooth running 4 cyl. 85 HP Merc.....I fixed up a boat for the kids when they were old enough so when we went fishing they had their own rig. No way Jose!.......figure of speech.
Good advise, I bought this boat with 2 friends, so we'll make the first run together, unfortunately I'm the only one that can make any fix but at least the pressure of my wife and kid will not be there.Good deal, glad for you and disregard the noise on this thread about anything else.
Post a video of the first run and speaking from experience DO NOT bri g the family it is bad luck. Do alone or with a buddy that can fix stuff. Then the family.
Well I bet you I can get a 50s OMC 25 hp to idle better than you can't get a 50s Mercury 4 cylinder 25 hp to idle.No, comparing the Mercury 4 cylinder back in the 50's to the OMC 2 cylinder engine, more cylinders firing made for smoother operation.....I had both. So what part of that don't you understand. How can 2 cylinders idle more smoothly that a 4 cylinder engine, much less a 6 cylinder? Makes no sense! If fewer were better, why not just save a lot of assembly costs and just have one big cylinder? I had a couple of those....Mighty Mite 1.7 Hp and 1970's era Mercury 4 or 4.5 HP forget which when I had my smooth running 4 cyl. 85 HP Merc.....I fixed up a boat for the kids when they were old enough so when we went fishing they had their own rig. No way Jose!.......figure of speech.
Maybe the comparison is not fair but my old Merc 50 hp with 4 cylinder trolls and idles much better than my force 85hp 3 cylinder, it simply sound and feels smoother and more even, but I'm also aware that force is not as good as Mercury.Well I would imagine your 115 with all the jury rigging done to it doesnt idle all that great. When I hear people talk about the tower of power Smooth idle is not the first thing mentioned. More cylinders does not mean better idling , the best idling motors are the old OMC 2 cylinder outboards. 3 cylinders tend to idle better than 4 and so on. The 2+2 is an incredibly good idling motor when set up right. And if 4 cylinders idle better than 2 why did Mrrcury make it a 2+2? Considering what you did to your 2+2 I don't think I will take your opinion on good idling. But hey you be you.
