[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Lou C
I can just imagine the conversations of people putting these together in Fond-Du-Lac, laughing to themselves at the poor guys who actually have to work on them....
The only I/O boat I'll ever have are the older, simpler kind, with wide open engine compartments, carb fuel systems, etc. I look at that and as nice as they work (when new) it makes my brain hurt lol. Changing a starter? A steering actuator? The engines are getting pulled then. In fact I convinced my brother to trade his 2020 Chapparal with the Merc 4.5 for a brand new Chap with a Yamaha 4 stroke outboard...before the headaches started. One bout of mild overheating due to marine growth in the water intakes (that I told him would happen unless they are rodded out) was enough for him.
You're on the right track Ted and you'll wind up with a unique boat, probably the ultimate for your boating area....as for me being the skinflint that I am, and admirer of simplicity, I'll stick with this.....
tpenfield
It took a while, but I got the lower bolt for the steering actuator loosened. Then I could remove the water intake hose and expose the rear mounting bolts.
They came out fairly easily . . .
I believe these are stainless bolts . . .
So, I just need to disconnect the fuel line and the starboard engine should be ready to lift.
tpenfield
Hi @Lou C - Yes, it has been you and I against the salt water Gods, so it seems. I will say that there is a lot of engineering that goes into these I/O (sterndrive) systems. Amazing that it has worked for so many years.
I'll be happy to send these engines to someone needing a twin engine re-power.
A bit late, but did you think about removing the oil cooler to gain access to bolts?
tpenfield
I did for a moment, but the steering actuator was more directly over the bolts.
tpenfield
A bit rainy today, so not as much work done. I did go to Harbor Freight to get a tool for the steering actuator.
I was able to get the 1" socket on the lower pinch bolt from above with this wrench. Much easier than yesterday's work.
I should be ready to pull the engines tomorrow . . . Here is where things stand as far as all the stuff to disconnect. I'm saving the fuel lines for last.
My learning curve kicked in and I was able to do stuff on the port engine in a fraction of the time. Just don't want to make a habit of pulling engines . . . :ROFLMAO:
tpenfield
! down, 1 to go . . .
I had to update my chart. As I was lifting the first engine, the starboard side did not want to go. So I put the engine back down and discovered that the alternator feed and Mercathode power needed to be disconnected.
Then the engine came up as expected . . .
The engine looks OK. I'll want to re-assemble some of the stuff that needed to be removed during the process, and clean the engines up a bit.
Now onto the second engine . . . :unsure:
aspeck
My wife is pretty understanding and easy going, but if I started a project like this in our driveway I don't think it would go over too well!
tpenfield
Engine #2 is done and safely on the ground.
Big milestone for this project . . . .Looks like I'll be cleaning up the engine bay tomorrow and then some. :LOL:
redneck joe
My wife hasn't had the garage in 6 plus years. She must love me..
Lou C
Wow great progress
I think if I tried that, I'd be getting what we used to call in Brooklyn
"La Faccia Brutta" from my better half, lol...
tpenfield
I'm doing this work at the summer house, so not a big deal as to the use of the driveway, garage, etc. Just as long as I'm done by summer time :ROFLMAO:
tpenfield
For anyone referencing this thread for engine pull, here is my final check list, as I added a few things on the fly during the 'pull'.
Ted, go to McMaster Carrs web site and have one delivered
