- Joined
- Jul 18, 2011
- 19,240
Because, that's why[Electric Steering preference . . . .] Why
It eliminates the hydraulic system for steering . . . I'm sure there are "pros & cons"
Sort of, but all goodBecause, that's why
Yes, this sounds like what I have on the Mercruisers. The electronics tell the hydraulics what to do. I saw some product information on Optimus 360 (3rd party joystick solution) that they now have an electric steering actuator, which replaces the hydraulic.Sort of, but all good
Mine has 4 hydraulic lines at helm going back to electric hydraulic pump that is mounted between the motors.
The steer by wire uses a similar hydraulic pump but also has a controller which controls pump
Yes, but currently the tongue weight is more than my truck can handle. Basically the trailer is not towable in its current state of balance.When you add the pod and new engines you will be back to counter-levered
55 gallon drums all over fb marketplaceGet a couple big totes, barrels or other containers, put them in the bilge and fill with water
Ibc totes all over marketplace around hereThanks guys . . . I did not think about using water to counter balance.
Of course 2,200 lbs of water is 35 cubic feet or 4' x 4' x 2' . . . I might be able to figure something out . . .![]()
