FishAtFive
- Joined
- Sep 3, 2025
- 39
Muffs are not useless...and, if you have diaphragm damage to the fuel pump that's the test.It's just a matter of ruling stuff out. I've now ruled out the carbs and entire ignition system. I'm thinking if I can find out the ideal starting RPMs I can test that and rule out the starter and battery. If I squeeze the bulb that doesn't rule out the pump, it could just be compensating for a bunch of different things like poor crankcase pressure, issue with choke solenoid, slow start speed. Unfortunately I only get a small amount of time each week to work on it. I work a full time job, go to night school and have 3 kids, cub scouts, sports, etc.
I've also found that testing on the muffs is useless. I need to fill a tank and test on that, which takes time.
The handful of times I thought something was fine in the driveway only to be dissapointed at the ramp tell me otherwise. I'll happily swap 20 minutes of prepping the test tank versus 2 hours back and forth to the ramp. I've taken apart the fuel pump and inspected it awhile ago, one of the first things I did.Muffs are not useless...and, if you have diaphragm damage to the fuel pump that's the test.
Best of luck to you, your obviously a thinking man but perhaps in this moment your "overthinking"
Yep , all the hundreds of thousands of peeps all over the world that use them are just wrong .I've also found that testing on the muffs is useless.
I use them. Just saying for serious diagnostics that require load similar to that of being in the water, using the muffs can skew the results and leads to false diagnostics. If ya'll going to get nitpicky over every little statement then that's your time to spend, I guess.Yep , all the hundreds of thousands of peeps all over the world that use them are just wrong .
They are actually a very handy tool ........but you do have to know how to use them![]()
Look, we all need to take a big breath. What Mc tool is explaining as you can do lots of things on muffs but you can't do everything. A test tank is great but not everybody has one. I do and I have test props to go in it. If you're talking about a barrel full of water that's not a test tank. We all understand that once you put a an outboard on load, now you've got a whole different set of rules.I use them. Just saying for serious diagnostics that require load similar to that of being in the water, using the muffs can skew the results and leads to false diagnostics. If ya'll going to get nitpicky over every little statement then that's your time to spend, I guess.
Yeah I made a mistake testing the charge coil and replaced that when I did not need to a few months ago. I need to get a simple analog tester that a guy like me can understand.Don't assume problems some meters are not overly accurate trying to read such small values. Especially digital meters you can't set meter and probes to 0 ohms with the side dial before actually measuring the suspects.
Yeah but , Im thinkin of all the guys I have seen that just dont know how to drive a meter to its best advantage , and all the good (ish ) looking meters that turned out to be crap.Don't assume problems some meters are not overly accurate trying to read such small values. Especially digital meters you can't set meter and probes to 0 ohms with the side dial before actually measuring the suspects.
I have a close friend that frequents estate sales and have put this on my list for him to keep an eye out for.get yourself an antique like this one with a 1 ohm full scale with thumwheel adjustment to dead)
Yes, everyone on here has these....in fact I have the original 30 volt battery. Tried to recondition it but some goo drip on my finger and now my face is gone!get yourself an antique like this one with a 1 ohm full scale with thumwheel adjustment to dead )
it needs an old 30V battery but I wired mine up with 3x 9v ones in series and it fits inside the case, works perfectly.
Vintage Bell System Telephone Volt Ohmmeter KS-14510-L5 W/ Case And Leads | eBay
KS-14510-L5 LEADS AND CASE.www.ebay.com
Not everyone knows your real name and I'm at work so I put in the abbreviated version of "crosbyman"sorry about your face (Cros ??) just get 3 ... 9v batt. connectors from Amazon and hook them up in series to replace the COSTLY 30 v battery![]()
