ShoalSurvivor
- Joined
- Aug 1, 2012
- 329
1999 Stingray 4.3 - owned since 2013. 216 hours on the meter.
Original bellows (25years); shift cable & cable boot replaced in 2016; impeller serviced regularly; trim sensors have been disengaged and “bypassed” since 2005. Primarily used in salt-water, but well rinsed with Saltaway and dry stored in warm garage with drive down after each use.
She started taking an a little water at end of the season. I was able to see a few drips down the inner transom wall below the Y-Pipe, but could not locate source. Water accumulates when engine is not running. I’m considering connecting hose directly to intake hose and running to see if any water leaks from engine, just to rule out any engine leaks.
Q1: Any reason NOT to run this test, or are there other things to test at this stage?
I’ve decided to tear it down to inspect and perform a transom service, and also replace the trim sensors, but have a few questions.
Drive has been removed. I found NO WATER in either u-joint or exhaust bellows. The gimbal bearing is clean and rotates smoothly with no play. Universal joints are in excellent shape.
I’d like to avoid pulling the gimbal bearing if there is no reason to replace it. (I don’t own those tools). The seal is probably original, but seems to be doing its job.
Q2: Ok to leave bearing and seal in?
Q3: assuming the leak is not affecting the 9yo shift cable, is there any reason to replace it, if no shift issues?
Q4: Is the bellows sleeve reusable, or should it be replaced? If replaced, and I slice to bellows to remove the bell housing, can I just tap it out of the housing (carefully) from behind? I've seen a lot of chatter about difficulty installing sleeve - any tricks on using install tool?
Q5: Parts-wise, I’m looking at Mercruiser or Sierra for bellows kit, and avoiding the cheap aftermarket versions. Any strong recc on Merc or Sierra (a little less expensive)
Q6: Same question for Trim sensors - Mercruiser or Sierra ok?
Q7: is the bellows tool needed for Gen2 with the sleeve, or can it be finagled on?
Q8: should I replace the shift shaft busing with the new dual seal bushing while I have it apart?
Thank you!
Thank you!
