I recently rebuilt the carburetor on my 81 25HP Evinrude, which i've done before with no issue, but for some reason this time couldn't get it to idle down. I think the problem is likely that one of the welch plugs wasn't properly punched in and it's sucking air. So I'll have to rebuild it again.
However, I needed to get on the water the next day, so I happen to have had a carburetor from at 35HP. Got it on, and it idled fine and passed all the in the driveway in a garbage can with water tests. However, once I got it on the water, it ran fine at full throttle, but I could tell it was not reaching the proper RPM and would only get me to 24mph rather than my typical 27mph with the 25HP carburetor.
My assumption as to why this is occurring, but please correct me if I am wrong, is that the jets are bigger and it's getting to much fuel. My question and the purpose of this post is, can I adjust the 35hp carburetor in some way as to restrict the fuel in order to get it to run at full throttle as it should until I can get the 25hp carburetor rebuilt properly and put back on?
