How to decarbon a 4 stroke
TnTommy
I’ve been looking into removing carbon deposits from my evinrude 50hp 4 stroke fuel injected, E50PL4SS, the manual says this should be done every 50hrs I bought the boat this summer and I doubt this has been done in the last 10years. The manual calls for Evinrude/Johnson engine tuner.The directions are to spray it in carbs or air intake, so with no carbs where would I spray it?
I would not worry about doing this.------Most 4 stroke engines in pickup trucks have not had this procedure done in 10 years ( 150,000 miles ) either.
Crosbyman
the 2005 version of an ETEC as a direct oil feed into the incoming fuel line for purpose of mixing in ..."some " X100 oil with Carbon gard.
you could always mix some in say 100/1 in your fuel supply or look at Evinrude products to mix in the fuel .
Some folks like SEAFOAM (see utubes) some folks don'T like it.
now the question... Having any problems ?
airshot
If it really concerns you, remove the plugs and spray in some SeaFoam, turn the engine over a few times with no ignition. Let sit for a few hours, if really bad do that a second time. Put plugs back in and fire it up. If there were lots of carbon buildup it will smoke like crazy, if not much carbon then lighter smoke. Being a four stroke, I would not expect much smoke, usually not much carbon buildup in them. If your engine is running well, why bother? Don't try fixing what isn't broke....
Mc Tool
A modern 4 stroke should not need de-carboning ..........unless is burning oil for some reason ( and then de-carboning would be the least of your problems ) or if someone has sugared your tank .
If , like me , you just want to love your motor a bit there are other worthwhile things you can do . :)
TnTommy
I was wondering if this was actually needed
TnTommy
It is running good
dingbat
Like most modern 4 strokes motors, this motor appears to be throttle body injected.
Remove the breather and spray the your "Snake Oil" of choice in the throttle body
TnTommy
Thanks for the answer I just wanted to be sure before I did it, although now I’m not sure I should
Mc Tool
Its not wether you should , coz a bit of sea foam or whatev isnt going to hurt at the least , its just debatable wether you need to . Tother hand its relatively cheap and easy and may well have a positive effect . :)
saltchuckmatt
That's either a miss print, from a two stroke or a manual that covers everything.
If an auto like my dead grandmother's Cadillac....was driven slow all the time then the valves get carbon on them. We used to pour tranny fluid down the carb while running and smoke the living snot out of a city block. Turn it off and wait a day, then drive it like you stole it.
Outboards can't really be lugged much....unless your just pulling logs all day at slow speeds.
I'd put the "new in a can" away and find another thing.
Also, I wouldn't fix something that doesn't need fixing. Would you do that to your lawnmower?
Shouldn't hurt anything...just can't justify I guess.
