hub dust cap
995jim
I need to replace my hub dust caps and want to go to the rubber plug center style for periodic inspections but wanted the audiences review of this style cap vs the standard solid cap with no rubber plug in the center. The current caps wont stay in place after i pulled them off for an inspection
thanks jim
Earl Cordova
Sounds like you need Bearing Buddies. The one with the rubber cap is for the style of axle that has a zerk fitting.
The dust caps with the rubber inserts are also for the type of bearings that have zercs on them. In this case you pull the rubber cap and stick the grease gun onto the zerc, pump 'em up and then replace the rubber insert.
Clean the hub and inside the dust cap with some solvent. When you push on, the little bit of grease inside the cap allows it to slip off
When you push on the cap, you sort of have to burp it. Then it will stay on
995jim
so is this cap acceptable to use with a spindle that doesnt have a zerk?dust vap.jpg
Gee, It doesn't look like it.
If the bearing assembly doesn't have a grease fitting, and the axle doesn't have one, you will want a Bearing Buddy type dust cap. The Bearing Buddy type dust caps have a spring loaded center with a grease fitting. The theory is that you pump them full of grease and the spring holds the center of the dust cap which puts pressured grease on the bearing.
Horigan
That cap with the rubber insert will work fine. I run them on my trailer. I would still grease or seal the outer lip, like Scott suggests, so that interface seals well.
Rich, Running those hubs will work fine, as will the solid dust caps the OP had. However, I think the OP wanted hubs that would continuously grease the bearings. In that case it seems like he needs a bearing buddy-style dust cap.
airshot
Only tried the caps with a rubber center plug one time. They came with a used trailer. After filling with grease, the rubber inserts kept popping out when going down the road, allowing the grease to come out. Tossed them and went with bearing buddies. Never interested in trying them again.
995jim
actually I had installed new solid zinc coated caps, popped them off for a periodic inspection and the next trip out I noticed 1 had come offand a 2nd was ready to fall off as well. So Im just determining the best way forward without losing more caps going down the road.
On trailers with brakes, heat from them can cause pressure inside the dust covers.
Of course, if no brakes, the bearings can be fully pumped up with grease.
Lou C
I have those super lube caps on my trailer and have had em about 20 years, I haven’t had that problem, it may be that the quality of some of the rubber caps isn’t that good or, a dragging brake or too tight bearing is causing one side to get hot enough to expand the grease. Maybe replace the rubber caps every so often? I put bearing buddy bras over the super lube hubs as an additional barrier to water getting in & this has worked very well. Last thing you might try cleaning out some of the grease (carefully, sharp edges on the cap) to allow room for expansion of the grease….
Secret to Bearing Buddies it to only pump grease into them if the piston has bottomed out and only add grease to get the piston to slightly move. You can tell if the piston had bottomed out if you can rock it with your fingers. Once the hub is full of grease, you should not need to be adding grease.
As far as the EZ-Lube axles(I call them LAZ-Lube) with the zerk on the end, I never use those to grease the hub. I only hand pack my bearings.
Fortunately, every trailer I own currently(2boat and a travel trailer) have disc brakes so I can see if there is ever any grease coming out the rear seal.
airshot
I have had many bearing buddies or other bearing covers like them over my 60 plus years of owning trailers. All the ones I had, had a small overflow hole so excess grease would come out that overflow hole rather than being forced out the seals from to much pressure. I just assumed all were made that way. Something I will definitely watch out for in any future purchases.
About once a month, I add a pump or so to each bearing buddy, or just until I see a drop if grease come out the over fill hole, then stop. Often takes barely any type of pump at all before seeing grease coming out. I do pull the hubs and clean and repack the bearings every few years just to get a good look inside and see how things are wearing. Even the bearing buddy manufacturer recommends repacking every so often when using their products.
Overfill doesn’t always work. Even if it does, the hub is over pressurized for awhile meaning you may have already breached the rear seal.
I repack every two years except one trailer which has vault hubs.
cyclops222
Every 10 or 20 years. Needed or not. I back right in with no cool downs. Fresh water.
995jim
what I noticed was that the new bearing caps i installed were stamped with a good tolerance to lock them in but once I removed them the diameter was compressed causing a lack of tight fit when wanting to replace. Im thinking the caps are a cheap, thin chinese POS.
airshot
Good possibility....I only buy the brand name units, never import copies if I can help it. Yes they can be difficult to get installed due to the tight fit needed. I don't remove them until time to repack the wheel bearings ( 2-3 years). In my 60 plus years, only lost one bearing buddy, fell out on highway, lost whole axle stub backing into my barn after coming in from July 4 fireworks about 6-7 years back. Carefully examination showed the hub split open allowing the bearing buddy to come out....of course, so did all the grease, bearing tied up, and axle stub snapped off in my driveway....considered myself lucky !! If they are not really difficult to install, they are to small...
