Boats from work.
MikeSchinlaub
Sorry for the lack of updates, but there isn't much interesting happening right now. I'm almost finished with a big Sea Ray, but it's just routine body and paint work.
Probably the most interesting thing is the '90 something Tidecraft the guy nex to me is doing a transom job on.
We'll be shutting down for the holidays next week too.
Always enjoy your postings
Everything slows down in the winter
Happy holidays
redneck joe
Ones 'routine' is another mans 'that's cool as s....t'. I like learning things I didn t know previously even tho I prob wont retain too much.
When in doubt post it up.
MikeSchinlaub
Here's what I was up to eight before Christmas vacation kicked in.
On the other side of the shop, the supervisor and new kid have been working on a, uuuhhhh, Chaparral I think it was? Anyway,bit has one of those power step swim platforms, and the boss had me fix the damage on that yesterday.
I brush gelled it, and the repair is under that ring, so nothing is visible.
Back on my side is a Crownline with a super crappy prior fix. On the bottom of the boat was a spot of gel sprayed over a huge area of automotive base/clear, over another layer of base/clear, over a badly matched gel, over a big patch of bondo, and finally over a ground and filled spot that went all the way through the hull. Notice I didn't say ground and glassed, because it was all filler, a bit over 1 1/2 inches thick.
MikeSchinlaub
Lotta putty. Stringer look ok?
The tiny bit of bulkhead I can see is dry, but we're not getting into the inside.
Forgot to mention, the new owner bought it this way and didn't know about it until the gel started chipping off.
MikeSchinlaub
Never heard of this boat manufacturer. 2013 Cadillac ATS. Weird, don't know how it floats.
Anyway, this is my coworker's car. She got locked out 2 weeks ago, and we did some damage trying to get in. I have a panel clip tool with a wedge end, which I hammered through the door seal (thought I got around it, but I was just in the fold) and bent the door out with. She grabbed a scrap piece of stainless rub rail and I scratched the hell out of it trying to open the door.
Closer pics in the attachments below.
So I'm fixing the damage I caused over vacation. Also, the previous owner left the wiring for an amp just hanging out in the truck, still hooked up. Since I had to disconnect the battery anyway so it won't drain, I went ahead and took those off and tied the speaker wire up.
I have also now realised that I closed the truck, which is electronic button opened, with the battery disconnected. Hmmmm.....
Hind sight, look up slim Jim to unlock the door
Look to remove back seat to get into trunk. Might be able to reach in and pull inside latch in trunk
Pmt133
Some have a key slot up by the license plate bulbs to get in as well so you don't have to pull the rear seat.
FLATHEAD
Hindsight, Probably would have been easier to call a locksmith. Air wedge is your friend. Good luck with the repair. 🤔
redneck joe
We paid a stero shop to install on wife's Mercedes and they left bare. Coul not figure out why kept blowing fuses.
MikeSchinlaub
All done for tonight.
There isn't much I can do for the trim. We don't have any flat/satin paint, and I wouldn't know how to spray it anyway. So I touched it up with a bit of single stage. At least it's not bare metal.
I was also thinking of hooking a charger up to the jump start points under the hood to try to open the trunk.
MikeSchinlaub
All done, she just left with it a few minutes ago. I'm not happy with the blend, probably the different between ours and cadillac paint, but you can't see it in the sun. The door seal came in a day early, so that's done too. I even figured out how to save her seat settings for her, took like 2 minutes.
