496 overheating
Butbro
My 496 2008 still gives alarm when I go over 30, but temp gauge does not move much..
New waterpump but same problem.
What can I check next.?
See video.
Earl Cordova
The water pressure switch on our boat has to be replaced every 3-5 years because it plugs up from the hard water in the lake we go to.
ROY WILLIAMS
New water pump but same problem.
MERCRUISER DRIVE UNIT GEAR.
exchanger engine coolant antifreeze 50% - distilled water 50%.
water pump parts MERCRUISER DRIVE UNIT GEAR
Butbro
Ok, but does every engine got one of those switch?
And where is it located?
Kenneth
Fun Times
Kenneth
The alarm could sound for a high number of things going wrong and about the only way to pinpoint what it may be is to have the engine scanned with a marine style scan tool of a few references of types available.
Your alarm is sounding a hard alarm at about 4200 RPM which is considered a critical issue to go into guardian mode like that.
Unfortunately, everything is a guess until scanned right down to depending on what design (number of wires and how connected up) the trim sending unit/s are for the trim gauge (which I can see in the video is broken/stuck all the way up) and could possibly sound the alarm to where it thinks you are way over trimmed at high RPM and lower the RPM until idle then do it again at 4200 until fixed... But again, just a guess not knowing you setup and there are many other things that could do the same exact thing especially on your engine model and the year of the boat as that is the year things really started to evolve technology wise for complexity.
Is your engine digital throttle shift or still mechanical throttle and shift (cable vs wires)?
The water pressure switch is depended on your engine models serail number as some may be mounted on the power steering oil cooler near the back starboard side or possibly moved back down to the sea water pump impeller housing item number 12 seen here, https://www.mercruiserparts.com/bam/subassemblydetail/43086244/28188353
If you are more of a do it yourselfer vs finding a marine service shop/mobile marine technician then there a couple of offers on Ebay to where you can rent a diacom kit to plug into a laptop and read live data and fault codes to see where you need to head for repairs that or if the budget allows of high dollars you could buy a diacom kit or hand held scan tool by buying either direct from rinda technologies or sometimes seen on Ebay too depending desired scan tool model you'd prefer...They tend to start at the $500.00 + range.... Renting one for 7 days is about $50.00.
▪ DIACOM Marine PC Software
▪ TechMate Pro Scan Tool
▪ Diagnostic Adapters
▪ CodeMate Code Reader
▪ Other Marine Products
▪ Web Store / Online Ordering
https://www.ebay.com/sch/i.html?_nk...2334524.m570.l1313&_odkw=rinda+tech&_osacat=0
If you need pro help and looking for mobile then depending on your location sometimes under craigslist under services/marine you might be able to find someone to help out on the water, etc..
Earl Cordova
Kenneth
I don't know for sure, but since yours is only 3 years newer than mine I would assume it does.
IIRC I heard it can be in several different places, but ours is on the top, middle, back side of the engine.
Do you have a scanning tool ? Otherwise you may be shot gunning parts a long time.
Butbro
OW681317
Your water pressure sensor (item 29) is on top of the power steering cooler which is at top rear of motor
This is all the Rinda kits for your motor. The cheapest ones of each type have just the 94006 adapter which is all that is needed for your motor. The others have additional connectors
Fun Times
And your engine parts catalog can be found in the following link depending on if you have a base or H_O model. (High Output).
Butbro
Ok, thanks.
I will try to put a new one there and give it a try.
Kenneth
kenny nunez
kenny nunez
If your problem is “Bravoitis” the problem is not the water pump.
Add a sea suction through the bottom and merge it with the incoming water from the drive.
Go on the Donzi owners site and you will find that Bravoitis is pretty common.
Opinion; don't see it being Bravoits because the Temp gauge isn't moving
