Best Aluminum cleaner/brightener available today.
looking for the best consumer (or commercially) available aluminum corrosion cleaner and brightener available today.
not talking big flaky white rust with pits, however the fuzzy haze that develops on aluminum boats, pontoons, aluminum block castings, transmission castings, aluminum wheels, etc. I do not want to bead blast the transmission or suspension or engine block.
I used to have a guy (industrial chemist brother of a co-worker that made HVAC cleaners) that mixed up a specific aluminum cleaner that made parts look like fresh castings. the stuff would dissolve skin and stained concrete/fiberglass/the apartment bathtub if you were not careful. however that was 25 years and 1500 miles ago. it was a spray it on, have hose ready, when the surface just starts turning black, rinse and scrub deal. if you let the surface turn completely black the part was FUBAR.
I used to use "pink stuff" AC coil cleaner, however post 2004, the stuff just doesn't appear to work the same.
tried some of the wheel cleaners from the local FLAPS, however same issue, doesn't really work.
Oxalic Acid works to remove the heavy white rust, but dulls the surface significantly. so not using it on these parts. Vinegar dulls the surface as well.
the NAPA aluminum brightener requires a mechanical polishing after. looking to find something that works without the mechanical polishing. Primarily because polishing a boat, diamond plate tool box, or a wheel is easy. polishing a transmission, engine block, and suspension is not going to happen.
So reaching out to the tin-boat and pontoon crowd along with the hotrodding collective to see what works good that you can still get your hands on to remove the light white haze and return it back to that bright as-cast look.
dingbat
The problem you’re facing is aluminum is white. The shine you see is a mechanical finish, either polished or rolled, which is easily marred by etching the oxide from the surface.
Your best bet is one of the aluminum tank truck cleaners. Seen it done at a couple of truck stops and the results were surprising.
No idea if this is the same chemical processes I witnessed, but it will give you an idea of where to start.
MikeSchinlaub
This is what we have, supervisor says it works really well. It needs to be diluted 10:1, so you will get a lot out of one gallon. Look for it at semi supply places. He said it will turn the surface black if you leave it too long though.
picked up a gallon of this cleaner from the local fleet store down the road., going to try it on a few spare parts first.
Pmt133
There's some HF and H3PO4 in there. It'll work alright. I'd go for the less diluted mixture what ever it reccomends and see.
dingbat
You beat me to it.
Aluminum losses it's "shine" when etched.
