Wondering if I can add power trim to my 82 mercury
Bribass
Hello everyone
I have a bass tracker with a 82 mercury 40hp 2 stroke. It have the manual trim and I was wondering if they made power trim for this engine. I know of the CMC tilt and trims but I was trying to figure out if there was a regular trim that I could put on it? I also was wondering what I could do to make it start easier? It is a great running motor but I can be a pain to start most of the time. Also it leaks water around the top spark plug, it’s just a little bit and doesn’t seem to be a big issue but why is it doing that? And is there anything else I should know/ do to it?
redneck joe
Welcome to the forum.
Where is the water actually leaking from.
I beleive you can add tbt, I have an 82 50 I'll check manual to see if it covers a 40. If so, you are looking at about a grand on ebay. I'd just pin it where it works best most of the time.
Starting, pull the plugs and see what they look like. Do you pump ball before starting?
Bribass
Thanks
I was thinking I could find a used trim and get a rebuild kit. I do pump the ball when starting, it’s kind of finicky it likes throttle. And the water I believe is leaking from the top spark plug. I read and saw that maybe could be a head gasket?
Bribass
Thanks
Also thanks
Replace the water jacket gasket.----There is no cylinder head on that motor.-----What is your starting procedure?-----What are the actual compression values?----Have you installed a new water pump impeller ?---
dwco5051
If my memory serves me right that there is no head gasket or removable head on those old Mercs. That leak is from the cylinder block cover which is basically a water jacket. If just a few drops now and then I would leave it alone as removing the cover to replace the cover gasket on a motor that old may end up being more of a job than expected due to snapped cover bolts. Look up cylinder block cover gaskets on an 82 40hp to see if I am right. I know the middle 70' models were that way.
Edit: Since I am still sitting at my computer I did look it up, Part Number 85490 block cover gasket.
jimmbo
I don't think there was a Power Trim System for the 2 cylinder 40hp. The Steering Yoke was different from the 50hp
Bribass
Thanks
Bribass
Thanks. My starting procedure is kind of by feel. But I would say I prom it rank it over a couple times do the throttle in the half or full position and choke it eventually. Sorry I don’t have a great answer
Bribass
Is there any way to tell if I can or can’t based on the motor and some mounts? Or not really? I’m not really sure how they go. The bottom would just connect to the mounts where you can adjust the pins and the top to the motor some how. Or need different mounting? I guess is there a good way to know based off of the motor?
Texasmark
Thanks
Most Mercuries in the pre-V6 lineup have integral heads that are part of the engine casting. What you have is a flat plate over the rear of the block that is only a water jacket cover to retain water in the block.....a quick look at the side of the plate will show only 1 gasket installed....engines with removable heads have a 2 gasket combination: Block to head, head to water jacket. Replacing the water jacket gasket is a very easy task. Biggest problem would be with corroded screws that don't want to be removed.
jimmbo
When you have the Water Jacket Cover off, check it for Warpage. If it is, a new Gasket will also leak in short order.
In regards to the Power Trim... Here is a pic showing the 35hp(rerated 40 back in 84) and the 50hp. The 50 uses a different Yoke and Transom Brackets that do have provision for Power Trim. The 35/40 doesn't . As Racer mentioned mentioned an Aftermarket is one way to go. I will say it is the only way to go
If the water leak is not too bad, you could dry it off and put a bead of silicone to seal it. Those 1/4-20 bolts that typically hold the water jacket to the cylinder head like to break.
When I did the gasket on my IL6, I probably broke 10 bolts. Luckily on that motor, the block casting was such that in most places you could drill thru it and install a new 1/4-20 bolt and nut. The job still stunk, however.
Bribass
Hello, I’m looking to use an aftermarket tilt and trim to add you my boat. I was wondering what brand to use? The boat is a 82 bass tracker with a mercury 40hp.
Thanks
redneck joe
You apparently started two threads on the same subject. A mod merged the two together into one.
Bribass
Ok sorry thanks. How do I start a new one asking about tilt and trim brands. So it won’t merge with this one
