Boat value
mauro.
I am wondering what you guys figure this Setup is worth that I have attached below.
Thanks in advance
Mauro
  • Boat.pdf
  • 21ft.pdf
roscoe
No one is going to download that.
If you want replies, post the photos properly.
But if this is legit, the answer is: it’s worth
What someone is willing to pay, based on condition, local market, and time of year.
bakerjw
They are pdfs.
No brand or model was mentioned that I saw.
mauro.
how do you put them into pictures?
I am still trying to figure out what model it is but the brand is Glasply if I am not mistaken It is paired with the Mercruiser 888 the details are in the pdfs
mauro.
Here is the description copied hope it comes through ok
will try with pics in a second
Features and parts 21 full cabin boat Engine, fully rebuilt ford 302. Machine shop work done by Automo ve Dans in Quesnell. Rebuilt Fall of 2025 Rebuilt Edelbrock 1409 marine 4-barrel carb 2 Flame arrestors Performance world Dual plane Aluminum intake Pertronix marine Distributor with Ignitor II module Highperformance 45000-volt igni on coil Taylor igni on cables NJK Br 6fs spark plugs Sealed power Hyp Pistons Sealed power cast rings Melling double roller ming set Melling oil pump Clevelite Bearings Comp cams marine camsha , li ers, and pushrods Fully rebuilt 351 heads with double valve springs from comp cams Thermostat Engine coupler All Fellpro gaskets Starter Also have original 2-barrel cast iron intake with Holley 2-barrel carb Barr marine Exhaust from previous owner manifolds previous owner never seen salt water Drive, Mer cruiser 888 in good condi on no leaks and fresh oil. Gears and U-joints are all to specs, 1:62 upper gear ra o. Have a full extra leg to go along although upper drive has a ra o of 1:32. Replaced all solenoids for starter and trim pump Replaced all transom bellows New water pump in leg Gimbal bearing Brand new Hustler aluminum 4 blade 19pitch prop Hydro fins Boat, Hull and stringers were supposedly done by previous owner although I have no other proof other than visual. I did all of the interior work and finished outside during past 3 years. Will sleep 2 comfortable but will need a ma ress. Have all the registry papers. Some features are. AJR windows Vinell Interior flooring LED outside ligh ng Farria gauges Hummingbird fish finder Wipers Independent 150 dB air horn One automa cally actuated bilge pump which turns on a red light on dash so that manually switched bilge pump can be turned on Mercury marine thro le Naviga on Lights (Green, Red, Yellow) 2 brand new 27 RV Cold Cranker ba eries Freshwater tank and pump not hooked up but tank is installed in its space Audio system with 2 10-inch subs and amplifier from Punch bass Juniper and birch interior Heater from engine coolant heat 2 brand new 27rv Ba eries Ba erie selector switch for bat 1,2 all or off. 2 interior lights in front berths Anchor and e down hardware mounted on boat Engine all new gaskets and seals Kiker 20hp Jhonson 2 stroke All igni on parts replaced including spark plugs Carb rebuilt New thermostat Fresh oil in leg Trailer, 1992 Ez-loader Galvanized steel trailer Has hydraulic brakes that will need a new piston at the hitch for full func on. Has all the papers for insurance
mauro.
Hope this works if not let me know
roscoe
Photos and description all showed up.
Whats it worth?? For me, not much. A couple grand maybe , if it really fits your needs.
Looks like a heavy old boat with a rebuilt engine. And I'm gonna guess it not real fast.
What do you plan on using it for?
bakerjw
When someone details every little item on a boat, they tend to believe that it is worth a lot more than it is. Are you looking to sell or buy?
Ayuh,...... In my world, it might be worth $1500. to 3500. in the month of May,.....
The big downsides are, it's Ford powered, with an antique drive,....
mauro.
Well l am looking to sell, was wondering what I could hope to get or list it for anyway
mauro.
Just noticed all the errors in the description somehow didn't come across that great I copied and pasted it.
sorry about that.
tpenfield
The trailer might be worth the most . . .
Ford 302/351 . . . Mercruiser 888 . . . . All old / outdated stuff. I would list at $3,000 and add 'make offers'
mauro.
too bad when you think I have over 7k in receipts from this fall😒
tpenfield
That strategy never really works . . . potential buyers will probably not care how much money you have invested in the boat.
You should list the boat for sale at a price that you think it can sell at and see how it goes. You can always lower your price. It seems like there may be a niche market for older Glasply hardtop models in the Pacific Northwest.
mauro.
Thanks for all the info I guess all I can do is try and see what I can get for it
two things get repeated often on this site:
if you want to make a small fortune restoring boats, start with a large one...
restore the boat for you, not for resale...
bakerjw
I can imagine the amount of money spent on the engine. Sadly it is not a high demand boat. Put i up for sale for what you think that it is worth so that you have some room to adjust as needed. Best of luck getting a good price.
OT You're way up there in B.C.
Well NW of Banff. Shuttled over there 4 years in a row and rode my loaded mountain bike back into Montana. Gorgeous country.
mauro.
So
Sorry about the late reply here, just saw it. yup that's what it seems to be turning out to a lot of money spent and not a lot coming back but oh well I guess that is a lesson learned.
That is quite the ways for a bike, but it sure is nice country.
