eggs712
- Joined
- May 8, 2012
- 373
The headliner is done, minus adding some trim where edges meet.
You can also see the Sunbrella curtains I made plus the pieces covering the hull/cap joint (not sure of terminology). When I replaced the rub rail rivets with #10-24 bolts, I installed really long bolts every couple of feet for easier solo install and/or future removal.
I have had some adhesive issues with the vinyl headliner. I'm using Dap Weldwood Landau Top & Trim contact cement rolled on. The first coat always sticks great for a few days before letting go, even before this hot weather began. A second application usually affixes the vinyl for good, but on the overhead pieces in the aft cabin, I'm on my third application from the vinyl falling down while I'm away for the week. The contact cement still seems sticky when this happens, so I'm guessing that the plasticizers in the vinyl are causing this problem. If anyone has any better insight into this, please let me know!
