inverted thread size of power trim at cylinder and trim pump to manifold block
Bt Doctur
Thanks
Bt Doctur
Bondo, pretty sure those are 3/8 inverted but what about the hose from the trim pump? 7/16ths??
Fun Times
From Hardin Marine,
Your Price:
$2.82
Quantity Add to Cart
More Info
Outdrive Trim Hoses - Short Radius (Priced per Inch)​
137-8403
This is a longer custom replacement trim pump connector hose for use when you want to relocate your outdrive trim pump and the stock hoses come up short. They are made from stainless fittings and high performance stainless braided hose.
  • Replaces Mercruiser # 32-861127
  • Will fit R/MR/Alpha I/II and BravoI/II/III
  • Trim pump to connector block
  • Stainless End to Connector Block: 7/16-24 IF
  • Stainless End to Trim Pump: 3/8-24 IF
  • Sold per Inch
  • Custom Made per Order - MINIMUM SIZE is 60"
  • NO RETURNS
Outdrive Trim Hoses - Long (Priced per Inch)
Your Price:
$2.82
More Info
Outdrive Trim Hoses - Long (Priced per Inch)​
137-8401
  • Replaces Mercruiser # 32-861127 and 32-861128
  • Sold per Inch
SAE inverted flare threads
if you are "repairing" the inverted flare port, there are specific cutters required.
