Shifting into reverse is really hard
TnTommy
Got a 2000 evinrude 50hp 4 stroke when I shift into forward it very easy, but when I go back to neutral it gets a lot harder and then if I shift to reverse it's really hard to shift but will go back out of reverse to neutral easy and then to forward easy. Cables are new
I unhooked the cables at the motor and moved the shift lever by hand and it's same thing I'll try to post a video of it
saltchuckmatt
Will do I'm in the middle of restoring it so as soon as I get it all back together I will
Racer is correct, it's hard on the lower end if you don't rotate the prop while shifting it not running.
Other things can happen too though.
