1989 omc cobra gear case problem
Jacobnya
Hi, i just got a 1989 bayliner with a 2.3 ford and a omc cobra tko outdrive. second trip out the forward gear and pinion gear broke some teeth off so i bought all the parts needed to rebuild it and dropped it off at the only omc dealer in town (yuma az).
the mechanic started putting the gear case together but has run into a problem with the pinion bearing housing he says that when he tried to tighten the bolts to the gear case the propeller shaft binds up and wont turn. he set the pinion bearing depth and has the forward and reverse gear set to the manufactures specs but when he tries to put the pinion bearing housing on it seems like the drive shaft is too high causing the housing to hit the thrust washer and thats with no shims so its really tight fight and when he bolts it down the propeller shaft wont turn. does anyone have any clue as to why this is happening? any omc mechanics out there that can help with this? any ideas or thoughts on this would be greatly appreciated.
thank you
88 Capri (2022 SOTY)
Is the propeller shaft too high or the pinion shaft too low?
Is the pinion gear positioned correctly on the pinion shaft? Ie: not being drawn high enough when the nut is tightened.
Jacobnya
what he is telling me is when he put the pinion bearing housing on he cant tighten the bolts cause it prevents the propeller shaft not to turn. i guess like if the pinion gear or pinion bearing is sitting too high. he said he put everything to spec with the special tools and its just not working. he showed me what was happening i saw that when he tightened the bolts to the housing i couldnt turn the propeller shaft. he says its not supposed to be that tight and that you should be able to turn the propeller shaft when everything is assembled.
Jacobnya
not sure about the nut being tightened or not but ill definitely ask about that
thank you
Besides the gears what else did you replace? Do you know what caused the failure?
My thinking is could there be damage to the gearcase or a difference in another part where additional shims may be required. #51 are shims, there are different thicknesses of shims available.
The pinion gear is drawn up the splined tapered shaft, if it's not tight enough it could possibly cause your issue.
Jacobnya
i got the part numbers off the damaged gears and bought those then i bought the lower unit seal kit and upper unit seal kit and also bought a new pinion lock nut. thats about it. oh besides a new impeller kit and bellos kit
Jacobnya
i will go down to the boat shop tomorrow and ask some questions about the pinion gear and nut also about what shims he has. he mentioned that he was gonna try to install the prop shaft bearing housing first then the pinion gear, or something like that.
id like to just get it back from him and take it to a different boat shop that works on OMC but hes the only one in yuma az where i live. i would even take it to phoenix az if i could find someone to take it to
