Chuck4741444
Thread starter- Joined
- Jun 6, 2020
- 146
Im needing to build a rach to hold (2) johnson 150 and (1) 200. How wide and how far apart should the wheels be to support these three motors
As wide as you need to fit the 3 motors ,I mean its not like they are going to fall over sideways with the 3 side by side on the same rack.Im needing to build a rach to hold (2) johnson 150 and (1) 200. How wide and how far apart should the wheels be to support these three motors
Don't even have to figure metacentric heights, righting moments, etc.If the combined center of gravity stay within the perimeter of the base, an item will not fall over.
As long as it doesn't move. Once it moves (wheels), you have to take velocity and mass into it to see if coming to an instant stop topples it over (tipping moments)If the combined center of gravity stay within the perimeter of the base, an item will not fall over.
Now you have advanced from statics to dynamics and the math has got harder by a function of 3. I remember years ago in the Navy being able to figure moments of inertia for flooded compartments out from the center line with y K&E slide rule. No way today, I have 3 pairs of reading glasses in the house and still can't find a pair when I need them.As long as it doesn't move. Once it moves (wheels), you have to take velocity and mass into it to see if coming to an instant stop topples it over (tipping moments)
Having 1500# of motor and rack moving will require a much wider base to ensure it doesn't tip as compared to a static rack
No difference than rolling a fully dressed big block on a cherry picker and hitting a pebble in the driveway..... There will be tears and blood and possible broken bones and words that make Navy men cringe
It's a little more involved than just a bit wider than the combined CG
An object in motion wants to stay in motionNow you have advanced from statics to dynamics
until i sell them or part them outDepends what you are building the rack out of.
A welded steel rack, may only need a wheel in each corner.
Something out of 2x6's on end, maybe 6 wheels.
Something out of 2x4's, gonna need a lot of support.
Why one rack instead of 3 separate racks???
You right, I have to much to loss if it fell overailAs long as it doesn't move. Once it moves (wheels), you have to take velocity and mass into it to see if coming to an instant stop topples it over (tipping moments)
