Sad boater here is an opinion, unbiased even if repetitive...from an intelligent source As you go down the list you will see a simple test as i suggested on the "non cranking test" as you aling rotor to outbound plug wire... and fire the amplifier manually with a ground tap. If i read this correctly you should clearly see the inbound HV jump to the outbound plug wire position across a few mm gap . if you don't the HV is exiting somewhre else and has suggested by jimmbo a test session in
FULL DARKNESS may show you where (big file separated... see step 3 in the 2nd half of the documeent..
DISREGARD faulty info at the beginning in para 1-2 since your amplifier
fires on grounds from points not opens !!
STEP 3 — SIMPLE ROTOR ARC TEST
Q: how does a 55 HP Evinrude triumph 1969 distributor work and why would inbound high voltage not exit properly to the sparkplugs
The 55 HP Evinrude Triumph 55 HP 1969 outboard uses a fairly simple
battery ignition system with a distributor—very similar in principle to an old car.
How the distributor system works (plain and practical)
- Battery → ignition coil (low voltage side)
- 12 V from the battery feeds the coil.
- The coil has a primary winding (low voltage) and a secondary winding (high voltage).
- Points open/close (timing switch)
- Inside the distributor are breaker points driven by the cam on the shaft.
- When points close → current builds in the coil.
- When points open → magnetic field collapses → coil generates high voltage (20k+ volts).
- Rotor distributes spark
- That high voltage goes to the center of the distributor cap.
- The rotor spins and passes close to each terminal inside the cap.
- It “throws” the spark to the correct cylinder wire.
- Spark plug fires
- Voltage travels down the plug wire → jumps the gap → ignition.
Why high voltage might NOT reach the spark plugs
If you know HV is being generated but not making it out properly, the fault is almost always
after or inside the distributor.
1. Cracked or carbon-tracked distributor cap (very common)
- High voltage leaks to ground instead of going to the terminals.
- Look for:
- Hairline cracks
- Black “lightning” lines inside (carbon tracking)
- Result: weak or no spark at plugs.
2. Worn or damaged rotor
- Burned tip or excessive gap to terminals.
- Rotor not aligned properly with posts.
- Result: spark jumps wrong place or nowhere.
3. Moisture or oil inside cap
- Common on marine engines.
- Causes voltage to bleed off instead of jumping to terminals.
- Result: intermittent or no spark.
4. Bad plug wires (high resistance or open)
- Old wires can internally break or corrode.
- You may have voltage at cap but nothing at plug.
- Check with ohmmeter (should be low resistance).
5. Weak coil output (borderline case)
- Coil produces voltage, but not strong enough to jump rotor-to-terminal gap under compression.
- You might see spark outside the engine but not when installed.
6. Points or condenser issues (indirect cause)
- Points not opening cleanly → weak collapse → weak HV.
- Bad condenser → arcing at points → reduced spark energy.
- Result: spark exists but can’t make it through distributor reliably.
7. Rotor shaft / distributor timing problem
- If the distributor shaft is worn or loose:
- Rotor doesn’t line up with cap terminals.
- Spark has too big a gap to jump.
- Result: misfire or no spark on some/all cylinders.
Quick diagnostic sequence (fast and effective)
- Check spark directly from coil
- Pull center wire from cap → hold near ground.
- Crank engine.
- Strong blue spark = coil OK → problem is distributor or wires.
- Inspect inside cap
- Clean, dry, no cracks, no carbon tracks.
- Check rotor
- Not burned, tight, correct height.
- Test each plug wire
- Swap wires or check resistance.
- Look at points
- Clean, correct gap, not heavily pitted.
One key insight (important)
High voltage doesn’t “flow” like low voltage—it
jumps gaps.
So even small issues (moisture, tiny cracks, slightly worn rotor) can completely stop spark delivery.
If you want, I can walk you through
step-by-step testing on your exact engine (no guesswork, just a 10–15 minute check sequence).
ok
Here’s a
simple, no-special-tools diagnostic sequence for your 1969 Evinrude Triumph 55 HP 1969 outboard ignition system to isolate exactly why spark isn’t reaching the plugs.
Step-by-step spark diagnosis (fast and reliable)
1) Confirm coil is producing high voltage
Goal: separate coil problem from distributor problem
- Pull the center high-tension wire from the distributor cap
- Hold it about 5–8 mm from a clean metal ground (engine block)
- Crank engine
Result:
- Strong blue snap spark → coil is OK
- Weak/yellow/no spark → coil, points, or condenser issue
2) Check distributor cap condition (this is #1 failure point)
Remove cap and inspect inside carefully:
Look for:
- Hairline cracks (even tiny ones matter)
- Black carbon “lightning trails”
- Moisture / oily film
- Burnt center contact
Result:
- Any tracking or cracks = cap is effectively “leaking voltage to ground”
3) Inspect rotor condition and fit
Check:
- Tip is not burned or eroded
- Rotor is tight on shaft (no wobble)
- No cracking
- Correct alignment height inside cap
Key test:
Rotate engine slowly and confirm rotor tip passes
close to each terminal (not a big gap)
4) Check plug wires (hidden failure)
Do this quick check:
- Pull each wire from cap
- Inspect for corrosion, green copper, or loose ends
- If possible, swap wires between cylinders
Simple test:
- Crank engine and check if spark “moves” with wire swap → bad wire confirmed
5) Verify points operation (critical timing switch)
Open distributor and check:
- Points should open and close sharply
- No heavy pitting or burning
- Correct gap (typically ~0.020" depending on spec)
Quick clue:
- If points are black, burned, or not snapping cleanly → weak or no spark
6) Condenser check (common silent failure)
Symptoms of bad condenser:
- Spark at points (arcing visible)
- Weak or inconsistent plug spark
- Engine may fire briefly then die
If in doubt → replacing it is often faster than testing
7) Mechanical distributor issues (less common but important)
Check:
- Shaft wobble (bushing wear)
- Excess play in rotor
- Timing advance sticking
Any wobble = rotor-to-cap gap becomes inconsistent → misfire/no spark
Fast interpretation guide
- Spark at coil BUT none at plugs → cap/rotor/wires
- Weak spark everywhere → points or condenser
- No spark at all → coil or no points switching
- Intermittent spark → moisture, cap tracking, or bad condenser
Key idea (this system’s weak point)
On these engines,
90% of “no spark at plugs” problems are inside the distributor cap assembly, not the coil.
If you want, tell me what you found in Step 1 (coil spark or not), and I’ll narrow it down to the exact failing part in one or two more checks.
coil spark is sttrong but does not reach the sparkplugs via distributor
Good—that result is very useful. It tells us something important:
Your coil is fine. The failure is definitely inside the distributor (cap/rotor/plug distribution path), not the primary ignition.
On your 1969 Evinrude Triumph 55 HP 1969 outboard, when you have strong coil output but no plug spark, there are only a few realistic causes left.
