I/O (Sterndrive) Conversion to Outboards
tpenfield
The sun is shining so I'm doing some more glassing. I did the crossbar pieces over the past couple of days, and today I glassed the center stringer . . . 4 layers wet-on-wet.
With the sun out, temperatures in the boat are 80˚F, even though it is only 60˚F outside. To keep the coldness out I put some plastic over the transom cut-outs and set them in place. It's a good thing I didn't toss them :p
Ted, will you be adding shelving to hold the beer er provisionings in the old bilge area? if you need a design for a service elevator, let me know. we did one that brings a blender and booze from below deck galley up to the cockpit. 2 ball-screws, a kevlar belt and a small DC gear motor. it would raise and lower up to 150#
tpenfield
The center stringer support is done. I do plan on putting in a floor of some sort to make for a decent storage area.
I did another test fit and decided to go up a 'wee bit' on the spacers. (0.45" up from 0.35"). The thinner ones were a 'smidge' too tight on the sides.
The alignment with the keel was dead nuts on as per my laser line tool, so I hope to replicate that with the thicker spacers.
