Aluminum boat leaking
iggyw1
Ensign
I have an aluminum boat that has a small leak in the rear end somewhere, but I cannot find the leak. I know it is somewhere behind the read bench seat, as I have a flat floor in the boat with some inspection plates I can unscrew and look down to see dry bottom of boat. No floor behind the back seat between this seat and stern, but when I am in the boat fishing, I need to use the bilge pump after about three hours on the water. I filled the boat with water in my driveway to see where water drips out under the boat while on the trailer, and no water comes out. I can leave the boat in the water overnight and no water enters, but when I get in the boat and sit on the rear seat, water comes in at a very slow rate. (When my weight is added). How can I find the leak?? TY
Must be a leak near the waterline.-----Any pictures of transom.-----Livewell leaking ?
On an aluminum boat, the leak could be at the front of the keel strip and enter the boat at the stern
If you have livewells, the plumbing could be leaking, especially if the plastic fittings are 15 years old or older
83bluefin
I’d leave the boat strapped to the trailer and dunk the boat at the nearest launch. Let the weight of the trailer pull the transom down. Then check to see where it is coming in.
If it’s not found, is it possible the splashwell or drains are letting water in? Or possibly a loose rivet hidden by trailer rollers/guides…
airshot
Not going to be easy, so get ready to get down inside with a flashlight when you are in the water. Going to take some time and hard looking, but you will find it with enough patience. Make sure the boat inside is good and dry before you start. Finding leaks from the outside are more of a challenge as the capillary action of the water can make a leak appear where there is no leak. Filling your boat with water on a trailer is dangerous ! Removing the floor and getting on your hands and knees will be better. Get some pics for us to help give you more ideas where to look.
Never fill the boat with water. That's an easy way to collapse the trailer and dent the boat by adding many thousands of pounds of water
Ifishmuskie2
I find the transducer screws leak. It seems people don’t put sealant on them. Sometimes it’s the drain plug. It seems like every old aluminum boat has a few loose rivets.
I take on a gal or two in a day and I don’t worry about it as I get water in my boats when I’m fishing and it rains.
airshot
A small leak is no big deal unless there is some chance of damage being done like wet wood, or water soaked foam. Over the years I had a few utility skiffs, nothing fancy, just a big rowboat. So what if it leaked a gallon, hardly noticed it, just pulled the plug on the way home. If you have a nice finished interior and do not want water getting where you don't want it, then fix the leaks...
airshot
Most older boats have small leaks, but not many people put in the maintenance time to fix them, or...they don't fix them correctly. Way to many good quality sealants on the market today to not spend some time fixing those leaks.
