Need help finding new alarm for tiller and fuel pump
frigidbass
I have a '94 challenger and need to find replacements for 2 items:
1. Alarm in tiller
I am assuming the advice is stay away from e-bay crap and buy brand name. Which brand name and part number for the alarm in the tiller? Pictures below, no part number left.
2. Fuel Pump
I want to remove the oil tank and pre-mix to avoid failures, which I just had on the water. What fuel pump or kit would I use to remove the pump assembly that mixes the fuel and oil together? The current pump assembly is pretty accessible so it seems like a small job, I'm used to working on vehicles.
Engine is a Evinrude 115 E115TLETS
It's been fun owning a boat wired by stevie wonder, the crap I found and fixed has been wild!
Thanks!
-FrigidBass
Get the fuel pump that attaches directly over the pulse port on the intake.----Look for it just in front of the starter.----438556
frigidbass
Thanks, is it a direct bolt up or will I need to fab a bracket? A lot of the "conversion" pumps on ebay use the pulse hose and a bracket.
The correct way is 438556 !!---And I clearly stated that it mounts directly over the pulse port on the intake manifold.----Used on the 88 HP models.
frigidbass
I see it now, I didn't understand the initial post as I read too fast. Thanks
Also need to remove the much mis-understood pulse limiter.----Plug that port.----The pulse limiter is a flow fuse for the VRO.---Not needed with the simple pump.
