I got a Yamaha electric starter on eBay (new) but it doesn't show how to connect the electrical cables
boscoe99
I would think a sticky bush button momentarily on switch would be more likely to be the cause of the relay acting up.
DeepCMark58A
And deal with those choices, there is a reason it is a fraction of the cost, e-bay seller isn't give a highly discounted price out of the goodness in their heart. Not saying it can't work, would not bet on longevity or reliability.
boscoe99
Agreed. If we are talking about a lesser quality part.
To me it depends upon the particular part(s) and its intended application. If a component of an electrical starting system fails on a motor that also has manual cranking capability (OP's configuration) that would not be the end of the world. I would choose the cheaper but perhaps less reliable part.
Mc Tool
Yeah , you gotta be smart about it coz some of it is crap but if you are ....say going to cut and weld a spanner for one awkward access job then why chop up a snap on when the chinese one will do the job .....or bashing one size down socket over a munted bolt head .
DeepCMark58A
Spend the $ on quality and cry once.
Mc Tool
The OEM's will certainly agree with you as to that advice.
If a guy does not need 100% quality, when 50% quality works for him, why spend the money?
Yep ,my neighbour is building a log splitter and needed a 33mm drill to go thru ½ inch steel plate ....43 bucks off ali ex and 180 bucks locally . Cheap one did the job and still looks new . Works for me ( mostly coz he used my drill press 😁)
