150 EFI low oil pressure
Jeff J
I received the attached photo last night. I went out this morning and everything checks out… plenty of oil, no stored codes, and good oil pressure that climbs with throttle. The only thing not checked was a higher power setting because it was on a lift in a slip. Boat and motor are 2 years old with 77 hours.
Shouldn’t a warning like this throw a code that would be stored in the computer?
When did Mercury quit building throttle controls that allow moving the throttle independent of the shifter? No disengage button on the pivot on this one.
muc
"Retired" Association of Marine Technicians...
Should probably check this in the water under load and at full RPM. If this is a problem of too much oil, restricted oil pickup or a failing sensor/wiring issue. It might only show up at higher RPMs.
It does and it did. Just need the right scan tool to see it. Scan tool will also tell you what RPM this happened at.
They didn't, there will be a way to select neutral if it's a Merc control. Post a pic and we can tell you how to do it. Or read the owners manual.
Jeff J
I will try to remember to take a picture when I go back. I think it looks like a standard side mount ski boat control.
I was just notified the low pressure warning came back on so I may be back down there Tuesday to run the boat on the lake to see if I can duplicate it. Or I may just tell them to take it to the local Mercury shop and let them deal with it. I don’t go on the lake during summer holiday weekends.
dingbat
Could be something as simple as a faulty pressure switch…. Low voltage, contact corrosion, etc.
Check pressure with mechanical gauge to double check
Jeff J
Shouldn’t it throw and save a code if it trips an alarm?
dingbat
Not necessarily.
It’s only going to throw a code if the cause of the fault is known to the system.
All the system knows is the signal coming back from the pressure transducer is outside normal (voltage) parameters.
Could be excess oil filter pressure, failing pressure transducer (ruptured diaphragm in transducer), low voltage feed to transducer, loose electrical connection, corroded terminal, etc.
muc
There are some codes/alarms that won’t be stored, but a low oil pressure fault will. Just need the correct scan tool to see it. The picture you posted is a Simrad multi function display. It will only show some of the codes and only when they are currently active.
Jeff J
I checked it with TechMate Pro. Not the best scanner available but it should show all current and stored codes on the motor. There were none.
It just concerned me that such serious alarm would not store a code. Intermittent problems are a pain to troubleshoot unless it can be forced to duplicate.
Jeff J
Here is the picture. Typical ski boat looking control. The center does not push in or it is locked up hard. It doesn’t feel or look like it is meant to. I think it is a 2023 Sea Ray. I don’t have the owners manual. Not my boat. Just one I do light maint on.
muc
You have a 4000 GEN ll Pistol Grip Panel Mount Remote Control with Fingertip Neutral Lock Release
The button with the Mercury logo should push in when the handle is in neutral. If it doesn't push in, something is wrong. You could try rocking the handle forward and backward while pushing the button. If that doesn't work, you will need to pry the button out to disassemble the control and repair the problem. Because the throttle only button will only come out (without breaking it) when it has been pushed in and shifted into forward, you will need to buy a new button ---- good news is they are only $10
Manual 90-8M0093272 REMOTE CONTROLS will have all the info to do this job. Note that if you haven't disassembled a control box before --- the grease inside is nasty and will get everywhere and won't clean off of the vinyl. Make sure you have lots of towels and fast orange hand cleaner!
I'm not real up to date on the Techmate but I'm guessing you may need to look in the History section. Look for fault seconds or freeze frame. The fault should be there unless someone has erased it.
Jeff J
Again, There were no saved faults nor active faults on the techmate. It’s not some random toy I picked up for a one time use.
As far as the control goes, if that button is the problem, it can go back to the dealer. I would think it would still be under warranty. Judging from what I have seen out of that dealer it’s probably an installation problem if it was rigging by them. I should have checked it against the other 3 boats just like it while I was there yesterday.
muc
If it's a 2023 there might be warranty left, it should have come with 3 years. Have the owner call a Mercury dealer with the serial number to find out the delivery date.
The Techmate is a good tool and should reads faults on this engine.
There might be something wrong with the ECM. It should store all Critical Faults. It should have stored this fault along with the Guardian faults that would happen with a 431-21.
Jeff J
That’s what I was thinking (except ECM bit). I recommended 2 local Mercury shops to the manager. The one on the lake is at least a month wait but the other one 30 miles away is likely have it done in a week or so. He will probably ignore me and take it to the dealer 70 miles away where they bought it. I wouldn’t let them oil the chain on my bicycle… if I owned one.
