This doesn’t look right to me
Jeff J
It sure seems like there should be a cotter pin or tab washer on that shaft.
Mc Tool
Yeah you'd think , but thats a nyloc nut and they do work so I guess it comes down to what your used to.
If your going to used nyloc nuts you really should used them once only .
Ha , I have actually been on the lake with a friend fishing and racing our dinghies when I suddenly started winning .....yep , his prop fell off......towed him home with a 2hp Mercury 😆
Small HP outboard? If so, that's common
Jeff J
Mercury 150 EFI. It looks like I have a proper hub kit for it. The nut was loose. Not so the prop rattled but nowhere near the 55.3 lbs feet the book calls for. This boat would have been delivered this way from the store. The same store that I complain about the most.
jlh3rd
hmm
Every hub kit I've used for my 60/115hp mercs. came with a tabbed washer.
Jeff J
Mercury manuals all show a tabbed washer arrangement. Every prop and/hub kit I have bought for a 150 Mercury had tabbed washers. I really should call the service manager or store owner and tell them all the crap I find on the boats they deliver. The list is long.
I think they installed prop with a Honda hub Mercury nut.
Jeff J
I don’t have the serial number handy. New boat last year so I would guess 2024 or 2025 model 150 EFI.
jimmbo
I remember even with the Locking Tab Washer, the Prop Nut had the Nylon Insert. I suppose the Nut with the Nylon Insert could be trusted, but only if it was replaced with a new One, every time it was touched by a Wrench/Socket
Jeff J
I was looking at hub kits this morning. I’m fairly certain they installed a Honda hub with a Mercury nut. The dealer sells both brands.
Other things this dealer has done:
Left SeaStar linkage finger tight.
Rigged a motor so it made contact with hull when tilted full up.
Connected systems that constantly draw power directly to the battery instead of the battery switch - batteries died in less than a week.
Left the front Bimini mounts off the boat.
One ski tow came with what appeared to be temporary hardware holding it in place. Just an all thread screw without a nut. The kit comes with a proper bolt and nut attached to the tow.
That was on new boats as delivered. They left a hose clamp off when they winterized a Cobalt. The hose blew off and filled the hull on the first trip across the lake. It’s pretty impressive how much water those V-8s can pump.
The list goes on
