[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
ok, remember it is me - what gaps?
Not sure what you are talking about, gaps?
In other news . . .
I need to get/make some new mounting plates for the instrument panel. The Honda stuff is different size/shapes, so most of the previous mounting plates need to be replaced. A few are staying ( GPS, Fuel Gauge) . . . I tried to find an exact match for the material, but struck out.
Helm layout with the Honda engines. I'll need to confirm things with the re-power shop.
Anyway . . . I decided to make all new instrument panel blanks and the re-power shop can cut openings as needed.
Here is my first attempt at the single by (Fuel Gauge) that will go in the upper right. (my handy work is on the right)
tpenfield
Gap . . .
1/2" gap it goes up about 1" . . . When I did the putty to secure the extension bracket, I made a gasket to prevent the putty from squishing out and falling on the ground. Accordingly, the putty squished upward, which I wanted. Going to fill the gap with VE putty and then scarf joint over.
redneck joe
since i don't mind playing the village idiot, for those unaware:
"VE putty" typically refers to Vinyl Ester Putty, a high-strength, waterproof filler primarily used in marine and composite repairs (like boat hulls). It provides excellent adhesion, osmosis resistance, and sands easily
redneck joe
not joints i know about from an early age, then i got into wordworking and learned about other joints.
Not sure how you will complete a scarf on just a half inch gap with the two units already installed?
Pmt133
That is (from quick glance) a clean GMT800.
Oh and good job. They kick the proverbial tires on you a lot or just an in and out transaction?
redneck joe
ok, so just glass. In my mind a scarf is one of the below not just glass over a filled gap, or will you offset the layers to achieve something similar to a traditional?
Ted, since most hull pods are just bolted and caulked........pretty sure the lap/butt joint is now under the over-kill category.
you should be fairing soon. time to make it smooooth and gel coat it.
redneck joe
i would overkill. it is just a couple layers of fiberglass imo. I actually did fiberglass as a kid on my Sears Ted Williams 12' Gamefisher. Keel started cracking. Lasted several years until i beat it up more. From 14 to 17 years old had lots of fun with that and the 15 Rude....
In my very non expert opinion i would do short first then overlap with the larger or do your layup then one more larger to overlap the two others.
Remember, i'm the village idiot...
Pmt133
Dad had a game fisher growing up as well. Had a 9.9 ted Williams outboard as well I believe. Used to overheat (he built it himself from parts) as the water tube wasn't aligned right. So your run it a bit. Stop. Dump water on the power head. Then go again.
I'm with joe, I'd go short side first as well. Granted for this, it really isn't as important. I just always felt it could get a smoother layup small to large.
