redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,454
looks cool what are the layers?
No it’s bought in. $25 his cost.dried in house?
3 cake 2 raspberry and 2 chocolate. The cake layers are just colored. Same flavorlooks cool what are the layers?
A friend of mine has the meater. He complains about it all the time. For a quick check of temp you can’t beat a thermapen.so tired of my Meater bluetooth probe. Too inconsistent in performance, battery usuage hih, not rechargeable, etc>
Anyone us one they like?
that actually was an issue i tried to overcome before. I was trying jerky in the egg but the element i used wouldn't stay low enough.Speaking of temp control,,, No help to your situation Joe, but I’ll mention this in case it helps someone else. I do my cased meats sausage, brats, sticks, etc. in an old electric smoker. I completely disabled the factory electronics on the smoker. I then wired the element directly to an Inkbird ITC 308 temp controller. As far as accuracy It is head and shoulders above any factory controller. Set it to your desired temp and it stays there, temp swings of only 1 or 2 degrees. Easy to bump up during a slow cook when incremental temp increases are needed.
No need for remote monitoring of box temp. It stays where you set it.
Seems most factory units have wild temp swings of 30/ 40 degrees.
I picked up the idea on the web.
I use a smoke tube and pellets for smoke.
All my other meats are done on a stick burner.
I have an inkbird probe but not wireless , I usually set a small timer (so I dont forget all about it ) and just go stab the roast . I like it cozSpeaking of temp control,,, No help to your situation Joe, but I’ll mention this in case it helps someone else. I do my cased meats sausage, brats, sticks, etc. in an old electric smoker. I completely disabled the factory electronics on the smoker. I then wired the element directly to an Inkbird ITC 308 temp controller. As far as accuracy It is head and shoulders above any factory controller. Set it to your desired temp and it stays there, temp swings of only 1 or 2 degrees. Easy to bump up during a slow cook when incremental temp increases are needed.
yes. I had one in Little Rock. I only went there about one or twice a year and he always remembered me and what beer I liked.and it’s usually the hole in the wall places that are the best.
