Oil change
TnTommy
I got 10 to 15 hrs on this oil it's black as coal, normal? Other than that I didn't see any thing alarming. I'm changing oil so soon because if the engine sits for an hour or more the no oil light and alarm comes on after starting, if I turn it off and start it back it goes away. So I changed oil sensor but it still does it , so I'm putting in Johnson/ evinrude oil and filter so hopefully that will fix it, I started it this morning and no alarm
tphoyt
I thought the rag was an iguana at first😂
Maybe the filter was letting enough oil through.
Best of luck
dingbat
Typical symptom of not using an oil filter with an anti-drain back valve.
jimmbo
At least the Oil's Detergents are keep that crud in suspension so it can be drained. Far better than having it building up on the Internals, while the Oil remains Clean, at 100 hrs.
How long have you owned the Motor?
