Windlass Goes Up but not Down
gman546
Issue i'm pulling my hair out with. Simpson Lawrence Sprint 500 goes up well but not down.
Its just a click and a nudge. seems like powers going to the motor but cant find any good information online about the system. I'm including a video to get an idea. I know in the video it doesnt show that it will go up but i went and manually let out some line and confirmed it goes up well, just clicks and sticks going down. can turn it freely the up way with my hand when i took it apart, but not the other way.
FYI I pulled the gypsey apart, took the chain off and had it under no chain load and still it moves up properly but down just clicks and stops in place. it wants to go, it tries. theres enough recoil in the "try" to make it just go the other way from the abrupt stop when it does try. cause the other way is free
How screwed am i?
Kosmofreeze
I just went through this with my Tilt/Trim motor/pump. It turned out to be some corrosion in the motor connector. First - If you can hear the relays 'click' when you hit the UP/DN switches - your switches and wiring are good. If not, it's either the switch or the solenoid. Find the electrical connector nearest to the motor. Probe the relay side of the connector with a DVM - you should see +12V/-12V when you press the UP/DN buttons. It that works, you know your reversing relays/solenoid working. Otherwise, replace the solenoid after you've ruled out the switches. To test the motor itself, run a 12V (assuming a 12V motor here) directly to the motor side of the connector. If you can get it to run UP & DN (+12V/-12V), you know the motor is good. Good luck.
gman546
I'm assuming the motor is fine because it goes up and pulls the anchor up. that has to be harder than putting it down? i do hear the click like it shows in the video. i'm confused if there was even a solonoid in this windlass or where it would be. the bow area where the motor is doesnt have any solonoid. maybe its in the engine bay?
It does have one and that's the biggest issue is finding where they put it
Look on page 10
Manual
gman546
Look on page 10
Manual
Ah I see thank you for all the links. they call it the "Control Box". Ok ill see what i can do hopefully just some corrosion there
most of the time the contacts in the reversing contactor arc over because they do not put a flyback suppression diode on the motor side.
tpenfield
Aside from any electrical issues as mentioned . . . I am wondering (asking) if the bow roller is the 'self-launching type' and if the windlass is set for 'free fall' feeding.
gman546
Honestly i have no idea the boat is new to me as of a few months ago and the previous owner said the windlass works perfect. I didnt check and have no reason to doubt that was his experience he was very honest about everything else.
This is the first anchor system ive ever had. never had a cruiser before so this is a 1989 sea ray sundancer 22da. It seems odd that it worked for him, but only “up” works for me. Logically, it feels like the system is working except for some small/simple issue. Otherwise, why can I pull the anchor up with the boat off? That seems like the hardest load the system would handle, and it works fine.
why would it have a down switch if it was that way? heres my cluster. green light on this always on btw
tpenfield
Well, you can test a few things . . .
Free fall . . . let out some chain (manually if you have to) so that the anchor is hanging from the bow roller. Then go hit the down button. See if anything happens.
Self launching . . . with the anchor in its full up position, loosen the chain (manually if you have to) and see if the anchor attempts to fall off the end of the bow roller.
gman546
Self launching . . . with the anchor in it full up position, loosen the chain (manually if you have to) and see if the anchor attempts to fall off the end of the bow roller.
in your scenario 1, i did that and manually let out some line by just bypassing the clutch or brake or whatever, then hooked it back to the loop/gypsey or whatever, and no same thing, just clicks. and same thing for your second scenario same result neither makes it free fall and i dont think its supposed to be that way
Contact arcing on a reversing contactor
gman546
I’ve tried but I can not find the relay for the life of me. The motor is in the front and goes this way with the wires. Solenoid not in engine compartment or under dash. No idea. I give up. No idea where it could or would even be. I took the aft cabin access door out and the cables are there but just go to the back. No saying if the solenoid is somewhere in the front or back of the boat. I guess every time I use the anchor I’ll just have to take the Gypsy off and manually put it down by taking it off the brake. It’s literally nowhere the solenoid I’m not convinced there is one. The clicking is also at the motor….so
gman546
This is whats under the helm by the switches. i dont think any of it is what were looking for 1782440630023.png1782440639293.png1782440665132.png
tpenfield
Yes, as AD said the solenoids should be near the windlass, so as to keep the high-current wire runs as short as practical.
arks
You gotta find the solenoids. They are there somewhere, and as alldodge and Ted mentioned, should be within a foot or so of the windlass itself.
Here is a picture of a typical solenoid panel, showing both solenoids and the circuit breaker. Maybe this will help. Good luck!IMG_0279.jpeg
gman546
Here is a picture of a typical solenoid panel, showing both solenoids and the circuit breaker. Maybe this will help. Good luck!View attachment 417393
I think its likely at this point that my system doesnt have solenoids. I can see where the thick wires go from the motor for at least 6ft and theres nothing there. I hear the click at the motor so my plan is to take the motor off, and test with the switch. If the switch makes the motor turn both ways, i'll know its the gears that are bound up. I hear it click at the motor though when i try to go down, it just doesnt do anything. the actual entire gypsey assemmbly nudges too like it wants to, so i dont think its the solenoid at this point.
