MikeSchinlaub
Ensign
- Joined
- Jan 14, 2025
- 924
Now you're getting it!@Drivewayboater2 This is not gonna be cheap....
We should all embrace the darkside.Now you're getting it!
It comes with unlimited power.We should all embrace the darkside.
but, that is fixable i'm told....Just don't grind a hole through the boat!
You have to finesse it a bit. As long as they aren't very deep, you can go back later with 36 by hand and smooth the sharp points. Or do a light coat of resin putty over as you glass.@MikeSchinlaub the problem is with that 36grit flapper disk it makes dips super fast in the fiberglass mabie i should switch to a electric hand sander to flatten everything out or take off that layer
Yes, but no need to add body and paint work to the list.but, that is fixable i'm told....
