Manerack12
- Joined
- Jul 6, 2026
- 2
I’m trying to diagnose a no-start issue on an older outboard motor. The engine cranks/turns over and the flywheel spins. I have power, new fuel in the tank, and new oil. I replaced the spark plugs with new ones and installed them, but the engine still will not start.
Fuel line has an inline fuel filter. I removed the air box/carb cover and can see the carburetor intakes/butterfly plates. When I spray a little starting fluid/fuel into the carb throat, the engine pops/tries to start for about a second, then immediately dies. Without spraying anything into the carb, it just cranks and won’t fire up.
So far I have checked/done:
Symptoms:
My main question: based on the fact that it fires briefly when sprayed into the carb but won’t keep running, would you agree this is most likely a fuel/carburetor problem? What should I check next before removing and rebuilding the carbs? Should I first drain/flush the carb bowls, replace the inline fuel filter, check the primer bulb/fuel pump/tank vent, or go straight to pulling and cleaning the carbs?
Any advice on the correct diagnostic order would be appreciated.
- New spark plugs installed
- Engine cranks/turns over
- Flywheel spins
- Fuel tank has new non ethanol gas
- Marina Grade 2 stroke Oil is present
- Inline fuel filter is present
- Air box removed so carb throats are visible
- Spraying into carb throat makes it briefly fire, then die
Symptoms:
- Won’t start on its own
- Briefly starts/pops only when fuel/starting fluid is sprayed into the carb
- Dies immediately after that
- Seems like spark/compression may be present since it fires briefly
- Suspecting fuel delivery/carb issue, clogged jets, bad primer/enricher, fuel pump, clogged filter, stuck float/needle, or fuel line/vent issue
