Mercury classic 40hp two stroke
aerobat
Hello friends !
I,m about to pull the trigger on a göetcher 14' with an mercury 40hp two stroke .
Not new to boating and its just an idea as a second boat for fun but honestly i do not know anything about this motor except its a 4 cylinder 40hp 2 stroke .
Searching the net gives me only little information about this motor .
Any ideas where to look more closely during inspection before finally deciding the purchase ? Any weak points on this motor ?
The boat / engine seems in decent shape for small money .
Thanks for any help !
jimmbo
It was introduced in the 1958 Model Yr. Basically it is 2 of the 22 cubic inch twins in one Block. Small Pistons and a short Stroke.
Crossflow Charging, Very smooth idling Motor
Last year of Production was 1996. 38 yrs is a long Run.
Post a Pic of it
airshot
I have a 1982 model and it has been an excellent motor. Mine has the oil injection system which has been flawless. My friend is a motor mechanic retired, but claims they work very well as long as you keep using the same brand of quality two stroke oil. Mixing together cheap oils can cause some issues, so I have been told. Bought mine from original owner and always used Oennzoil so that is what I use.
Check the compression, check for lower unit leaks, and be sure all the fuel hoses are in good shape under the hood. Mine idles so slow you can almost hear each cylinder fire. Been very happy with mine !
jimmbo
The Oil Mixing System wasn't introduced on the 50hp till 1986
Mc Tool
It used to be a 50 HP.----Now prop rated at 40HP.-----One of the best they marketed.-----Do a compression test.
Sounds like an interesting motor .
Seems a few motors from that era had a lot of cylinders for what is not a large motor , Honda's 6 cylinder 125cc and 250cc gp bikes and Ferrari 1.5 and 2.5L V12's spring to mind .🙂🙂
jimmbo
Mercury used to basically add cylinders of the same Bore and Stroke
In the 50s they used the 20 inch Twin, doubles as a 40 inch 4 Cylinder, and in 57, added 2 more to make the first inline 6. Fast Forward to the 70s and the 33.3 inch Twin Bore and Stroke, used on the 40hp, was doubled for the 66.6 Inch Block used for the 800, 850, 80hp and 75hp. 2 more Cylinders made the 99.8 in block that was the Basis of the 1150, 1250, 1350, 1400,1500, 900, and later 90, 115, and 140. Pistons and Blocks varied. Early ones were all CrossFlow, Later 33, 66, and 99 blocks were Direct Charge, and some of those were Power Ported, which also required a different Piston.
The V6s never added more Cylinders, though there are Rumours of a V8.
Mercury did make a 12 Cylinder Outboard at one point, they used 2 V6s mounted beside each other, facing opposite directions, they were coupled together. They were Fuel Injected, as shown by the Silver Fixture on the Side of both Blocks. As far as I know, it never got past, the 'Can we do it' Stage
Here are a couple of pics of it. Next to it is Jerry Hale the Chief Engineer of the Mercury V6
aerobat
Great information so far gents !
I will inspect the boat next weekend so then i will post a pic .
I believe its a 1992 model . Does it have the oil injection with tank ?
Its a fun idea , like said a 14 foot fletcher arrowflyte with this motor . Curious how it runs with it.
Yes , i think i will check compression . Obviously i,m hoping for similar results on all cylinders , but what numbers i,m looking for ? +100 psi is ok ?
Texasmark
Post a Pic of it
......and then they tossed another pair of cylinders on top of that and came out with the Tower of Power......had a 1988 115....one badass engine. It loved for you to push the throttle to the firewall.
jimmbo
No, the 1957 Inline 6(60hp) was an extension of a 40 inch block. The 50hp was the 44in block. When they added 2 more to it, it became the Merc's 75hp
Texasmark
Yes sir. I used to have a picture of Roy Rogers driving his 16' moulded plywood Yellow Jacket with the newly minted 60 HP I6. I understand that he was a stockholder in the Yellow Jacket boat works, and maybe/or in Mercury Marine.....had the boat full of Dale Evans (wife) and his kids.
I realize that 1988 is way down the production line from 1957. My engine was Direct Charged, rather than just Cross Flow. I didn't have a boat then, as I was a sophomore in high school and dad had a 10 HP Scott Atwater we used on rental boats when we went fishing.
What is the difference( if any ) between a crossflow piston and a " direct charge " piston ?
jimmbo
Direct Charge, a variation of the Crossflow, with a different Deflector Shape which may affect how it scavenges the Cylinder. It also allows for a lighter Piston with less of a Heat Sink on the Crown
airshot
You had stated you had a feature, 2 yrs prior to it being Introduced
Not on my 40 hp....serial number and title show 1992, if you look up that year and model, most all have oil injection. They were very popular because they actually produce closer to 45 hp than 40 hp.
airshot
Actually checked a Mercury outboard website and according to Merc the oil injection system was incorporated in the late 80's then well into the mid nineties. Very popular and had very few issues.
airshot
Reread what you posted in Post #4
My apologies, just realized it posted 1982 and should have read " 1992" ...damn spell checker or what ever it us called often changes characters that I don't catch....don't know how to turn it off...
Just went back to recent posts and found more character changes on them !!
