FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I believe the factory seals use a stainless metal casing.--Not all seals are stainless.----Proper bore interference fit as well.----I also dislike seals that are covered with rubber all over.
Oooh I do like the rubber coated ones ....sorta self sealing and fitting in the bore and thusly bore interference isnt critical . I have used the non coated ones and yes the bore fit is important with them but then the also need some sort of sealing compound on them to insure they dont leak around the outer circumference of the seal . Im thinkin too that the non coated ones I have sourced/used have all been nos parts on older stuff . I think rubber ones are ok I mean its not like the seal is load bearing , all they have to do is stay in place and anything with a bit of pressure behind it usually has some mechanical retention involved.
