V4 - Minimize Chances of Broken Rings
Berdink
I've read threads where ones say the V4's are prone to rings breaking - catching on the cylinder walls where there's openings.
Is there anything I can do to minimize that happening?
Like an additive like yamalube or mixing a stronger oil to fuel ratio, or....?
jimmbo
A lot of the Ring Problems were the Result of OMC moving the Rings closer to the Crown(top) of the Piston. Over Propping, resulting in a too low of Max WOT Rpm, and high Piston Temps adds to the problem. Wrong/Poor Oil can result in Carbon building up behind the Rings preventing them from expanding-contracting
Best ways to avoid/reduce the Risk, is Prop the Engine to run in the Upper Half of the WOT Range.
Use a Good TCW-3 Oil. Myself, that would be BRP or Mercury Oils(that should start an Oil War). Yamaha has some very good 2 Stroke Oils too
Regularly use BRP Engine Cleaner/Mercury Power Tune to remove Carbon from behind the Piston Rings.
Those Engines are Speced to run 50:1 if using Premix. If the Motor has VRO/MRO, the Pump will mix the proper amount of Oil into the Fuel
It is a fact that the rings will break at some time!----Simply due to the shape of the top ring.
jimmbo
Those Wedge shaped Rings? I think they were call "Pressure Backed", at least by Evinrude. They were first mentioned in the 1970 Model Yr
Berdink
Do the Wiseco brand pistons fix this issue?
Is it worth upgrading to those in such an old motor?
Mc Tool
Yeah , everyone else calls them keystone rings . Lots of motorbike have used them and the only real issue , apart from abuse ,was excessive wear allowing worn thin rings in worn oversize ring grooves to twist and jump out the exhaust port or override the locating pins and poke a ring end out of a port.
You can do stuff to minimise wear or prolong engine life but when its knackered its knackered .
Just use the boat and dont stress out over it 😁....if it sucks a kumera it wont do all cylinders at once and you'll make it home 🙂🙂
Mc Tool
If/when it happens to me, it sounds like many upgrade to Wiseco.
Wiseco sure are good slugs , I fitted s set of them to a 70hp Johnson that was melting pistons (bit of a story) ...and it ate them too .....no fault of the pistons . I think their biggest advantage is that they come in larger oversizes that the stock pistons which gives you a couple more "lifes" when rebuilding .
Berdink
I read somewhere, and it may be wrong, but thought I read that they dropped the top ring down a little on the piston making it possibly less vulnerable.
Berdink
I have no idea why the stuck with the bad top ring design for 25 years.----Such an obvious defect.
So, I could run it until it breaks a ring, but don't I risk when the ring breaks it scouring the cylinder wall, or chipping a portion of a port?
We'll see how this motor ends up working out for me, and if I decide to stick with it rather than find a 70hp, I'll likely just do the upgrade during a winter.
